101Views6Replies
Author Options:
Heat sensor? Answered
I need a heat sensing circuit that detects, if my server blows out warm air to switch on forced ventilation.
This module should work as a stand-alone module without any connection to the server.
lemonie
lemonie
8 years ago
I'm good sometimes...
Can you fix this with ducting or is the box too big?
L
steveastrouk
steveastrouk
8 years ago
http://www.rapidonline.com/SearchResults.aspx?kw=mic502
steveastrouk
steveastrouk
8 years ago
Well, since you didn't exclude the simplest solution, you got the simplest solution.
In that case I recommend the Micrel Mic502 IC, which uses a thermistor to give you a PWM motor speed control. Perfect for your requirement.
http://www.micrel.com/_PDF/mic502.pdf
Bernhard 52
Bernhard 52
Answer 8 years ago
Well, I dont believe it !
This is exactly what solves my problem !
Now I have to find a dealer here in Gemany,
who sells some of those mic502 to me.
Thank you very much !
steveastrouk
steveastrouk
Answer 8 years ago
PM me if you want one.
rickharris
rickharris
8 years ago
Just run an exhaust fan ALL the time - Over cooling isn't a problem for a PC.
lemonie
lemonie
8 years ago
This is one of those "Guess my problem?"-questions.
I guess that you've got a computer in some kind of box or cupboard, and you know that it gets too hot because it's in a box.
So you want something that effectively takes the place of opening it up to let hot air out. And you want to just leave it alone.
-Make sure the fan that the server already has (server blows out warm air)  is blowing out of the space that the server is in, and that you've got a cool-air intake. Some kind of ducting should do it.
L
lemonie
lemonie
Answer 8 years ago
Careful now, we don't want to blow anyone's mind with wacky-ideas...
L
