146Views5Replies
Help! How do I use Sculpey Properly?
I am new to the modeling clay art form. I have been tasked with creating something. I bought sculpey to use, but dont know how. Can anyone tell me how to use it properly?
Best Answer 6 years ago
I am unsure what you mean by properly.
Shape what you want as if it were modelling clay.
Following the instructions on the pack put it in an oven at the right temperature and wait the required amount of time.
It will be hot so take care.
Remove an allow to cool.
It will then be hard.(or at least fairly hard - Some will go very hard and some is like a hard rubber.)
https://www.youtube.com/results?search_query=using...
Answer 6 years ago
I know I sound like a newb, but when I researched it, I was told to never use a metal pan, but it didnt say anything about glass. The two things it recommended were an oven safe pizza plate or something similar. Sculpey and other modeling clays are expensive here, so I didnt want to mess it up and waste clay
Answer 6 years ago
^^^ thats what I meant by properly
Answer 6 years ago
I generally put it on a bit of aluminium foil on an oven sheet. Watch the temperature though as it can burn. Otherwise follow the instructions on the pack. It is easy really.
Answer 6 years ago
oh,ok. One last thing. Do I need to ventilate the area?
Answer 6 years ago
Not especially - Provided you stick to the reccomended temp then you will be Ok.
IF you over heat it it may smell a bit.
