412Views15Replies
Author Options:
Help! My Leds wont sync to the music! Answered
okay, so here is my problem: i have done this tutorial, and have had no luck....
i got all my parts from radio shack yesterday, ( Transistor, LED, switches, etc....) so they aren't old, and to make sure, I just tested the two transistors, and the still are working, same with use, battery.
I do not know what i am wiring wrong, but please help!!
here are the pictures of the wiring
steveastrouk
steveastrouk
Best Answer 10 years ago
LEDs the wrong way round ? In the circuit shown in the tutorial, the battery is the wrong way round.,
Re-design
Re-design
Answer 10 years ago
If the battery was reversed wouldn't that be backward for the transistors?
Hackrtanman
Hackrtanman
Answer 10 years ago
no, at least i dont think so. Resistors only go one way, and that is from Base, or B, to the emitter, E, i think....then the collector, C, gets added on for more power
steveastrouk
steveastrouk
Answer 10 years ago
No, I've reviewed it again. As shown, the emitter of the NPN transistors is forced positive, and the collector negative. The LEDs are shown as emitter loads, and correctly oriented for the transistors, the power is definitely wrong. Don't let the voltage at the base go more than .7V, or you'll damage the transistors that way too.
Hackrtanman
Hackrtanman
Answer 10 years ago
so what should i do to fix this?
steveastrouk
steveastrouk
Answer 10 years ago
Fix what ? Base resistors ? Add a 100 Ohm resistor to the base in series.
Re-design
Re-design
Answer 10 years ago
I bow to your greater knowledge!
lemonie
lemonie
10 years ago
You want to draw this nicely, I'm not sure which things are what, sesp. the black blob. Where is your input?
L
Hackrtanman
Hackrtanman
Answer 10 years ago
sorry, the black blob is just covering up the other transistor, so pople woulndt get confused....I'll draw one soon!(well, a diagram anyway,)
tomtortoise
tomtortoise
10 years ago
Maybe you don't have the volume loud enough? Bad song choice/not a loud song?
Hackrtanman
Hackrtanman
Answer 10 years ago
well, my ipod is on full blast, and the song choice was by the offspring, which is a rock band, and pendulum, a techno-ish rock band, so i dont think it was that
Re-design
Re-design
10 years ago
Well for starters, That's a stereo plug and I only see two connections.
The original diagram has two transistors and your's only has one.  Look at the PC earphone here.
Hackrtanman
Hackrtanman
Answer 10 years ago
Okay, so I just hooked up the second speaker, and the speaker works, but the lights still dont work
Hackrtanman
Hackrtanman
Answer 10 years ago
the plug does have a third connection, its just off the picture, you can kind of see it on the left side, its green. The plug came off of headphones, so it should work. Also, i just wanted to try using one transistor, because i wanted to make sure it work and all.
Re-design
Re-design
Answer 10 years ago
Ok but what does the third connection on the jack connect to?
Hackrtanman
Hackrtanman
Answer 10 years ago
the thrid connection is the other positive for the other earbud
