63Views1Replies
Author Options:
Help for making an Arduino powered Nixie Bar music visualizer Answered
Hello everyone!
I would like to make a nixie bargraph music visualizer which is controlled using an arduino.
The problem is i can find guides on making one without the arduino, or with the arduino but without the nixie bars.
How do i combine these two together and what about the code?
Are there some kind people on this forum who will assist me accomplish this goal? :)
https://www.youtube.com/watch?v=___XwMbhV4k <- Arduino
https://www.instructables.com/id/Nixie-Tube-Music-Visualizer/ <- Nixies
caitlinsdad
caitlinsdad
4 years ago
What you should do is to build two separate devices first to understand what you need to do. Build an arduino bargraph music visualizer( Adafruit ampli-tie project) that lights up LEDs and build a nixie tube visualizer. If you understand how the LEDs are being lit up, that same signal can be used to light up a segment of the Nixie bar. The hacking is to probably change the code so that it can activate a relay or turn on the switch for the high voltage Nixie segement. Good luck.
