1650Views12Replies
Author Options:
Help making LED light boxes w/ strobe functions for stage? Answered
Hello, im brand new here!
Im hoping someone could help me with the electronic side of some LED lightboxes im trying to build for my band.
The boxes im imagining have a face approx 30X10cm with approx 50 LEDs in each and i plan to build two identical boxes, one for either side of the stage.
Can anyone help with maybe a schematic or some instructions as to how i can build and power such units?
And if anyone is willing to help further, i would also like to have a built in function where the lights stay on solid, but can strobe (like a regular strobe light) when activated by a foot switch wired to each box.
Im not bothered if it requires a separate individual switch wired to each, or if its possible to wire a single master to both.
Hope someone can help!
steveastrouk
steveastrouk
9 years ago
Not difficult. The issue will be the power drives to the LEDs, what LEDs are you plannng to use ?
Steve
jetbones
jetbones
Answer 9 years ago
Hey! Im not sure sorry, im not really knowledgeable in the components department. Preferably bright white ones? :)
What would you suggest?
Thanks
James
steveastrouk
steveastrouk
Answer 9 years ago
Start with the LEDs !!
Where are you in the world ?
Steve
jetbones
jetbones
Answer 9 years ago
Australia
James
steveastrouk
steveastrouk
Answer 9 years ago
Take a look at http://au.element14.com/
jetbones
jetbones
Answer 9 years ago
Thanks, but i have no idea what im looking for, sorry
Maybe instead of "not really knowledgeable" i should have said "Clueless"
And instead of help i should have said "please show me exactly what to do"
haha
Can you still "help"? :)
steveastrouk
steveastrouk
Answer 9 years ago
Hmm. The device I was looking at, which is 6 quid in the UK is 47 AUD !!!!!
Take look on Ebay for high brightness white LEDS - you should be looking at stuff like these:
http://cgi.ebay.co.uk/2pcs-MR16-12V-Warm-white-Energy-Saving-Bulb-4x1w-LED-/160596029764?pt=LH_DefaultDomain_0&hash=item256444f144
These are going to be very easy to mount, and to drive lots of them. Buy as many as your budget permits.
Steve
jetbones
jetbones
Answer 9 years ago
Ok great!
Thanks heaps!
By mount, do you mean they will require a socket?
Should i be able to source them localy, or would mounting them onto a MDF or masonite board be sufficient?
And, is it possible/difficult to link these up to a single power source?
Obviously im going to focus on getting the basic prototype up and running, but at a letter date, would you be able to assist me with the strobe functions?
Thanks so much!
steveastrouk
steveastrouk
Answer 9 years ago
Yes, they'll need a socket. The ones I've suggested are just like the low voltage halogen lamps, so they need a very small connection on the back.
Wire them all in parallel, and connect to a 12V supply, see if that's the kind of brightness you want, then making them strobe isn't going to be too hard.
Steve
jetbones
jetbones
Answer 9 years ago
Hey! Ok its been a while, i got the boxes up and running a couple of months ago and have been enjoying them with their basic ON/OFF switch just fine.
Now im ready to get a little more interesting.
These are the lights i ended up going with:
http://www.jaycar.com.au/productView.asp?ID=ZD0462&keywords=LED+strip&form=KEYWORD
They're quite bright and run off of a 12Volt battery. Can you suggest where i can look now to implement the strobe functions i mentioned above? And hopefully also guide me in implementing a remote foot control to switch between steady and flashing?
Thanks!
jetbones
jetbones
Answer 9 years ago
Cool! thanks! will see how i go!
james
jetbones
jetbones
9 years ago
I just found these on ebay:
http://www.ebay.com.au/itm/AU-2-48-LED-Car-Truck-Flashing-Strobe-Light-Amber-Grill-/220689808751?pt=AU_Car_Parts_Accessories&hash=item3362233d6f
I think two of these panels in each box would be ideal (a bit bigger than i outlined but not a problem!)
and they seem pretty cheap.
does anyone have experience with these?
or could help me wire them to suit my needs?
thanks
