114Views5Replies
Author Options:
Help needed with flashing brake light microcontroller Answered
Hi All
New here and hope you can help me out.
I am a biker in south africa and would like to put together an aditional brake light that flashed 4 times then go solid.
Microcontroller will most likely be the easiest and have design one as follows. (the coding has been done)
LED's to be used is 20mA at 2.2V
My concern is that for the amount of LED"S (100) i want to use 1amp is not enough and therefore i am using a LM7810 to drop the voltage from 12V to 5V with a cap to increase the 1A output to 5A
I wish to wire the LED's in parralel si if one pop's then it wont affect the rest of the LED's.
Must i therefore still wire a resistor in front of every LED? (180ohm?) or can i wire in this LED before the LED matrix to give it a 2.2-2.3V throughout the LED matrix?
Here is my design : http://i247.photobucket.com/albums/gg156/HannesNel/design_zps52f754cf.png
2nd EDIT :
How about this? reworked the design a bit?
Then i drop the 12v down to 2.5V needed for the LED's and no resistors needed?
I also opped for the LM350 due to the higher amps it can handle
http://i247.photobucket.com/albums/gg156/HannesNel/Untitled_zpsc9900901.png
3rd update:
Now using super bright LED's with a rating of 2V and therfore will use row of 6 in series to give 12V...still need resistors when connecting the 6 banks of 6 LED each in parralel?
http://i247.photobucket.com/albums/gg156/HannesNel/Untitled_zps684a2209.png
Tags:design
steveastrouk
steveastrouk
6 years ago
Put the leds in chains of 5, and you'll only need a 47 ohm resistor, though you need 20 chains, in parallel.
steveastrouk
steveastrouk
Answer 6 years ago
You might find it doesn't get quite as bright as you expect, but you should be OK. Use a MOSFET for the drive transistor, and you should be OK.
HannesN
HannesN
Answer 6 years ago
a mosfet instead of the irf510? Or in addition?
steveastrouk
steveastrouk
Answer 6 years ago
The 510 will be OK.
HannesN
HannesN
Answer 6 years ago
see my second edit the OP...my concern with the chains is if one LED in the chain fails then the entire chain is dead
steveastrouk
steveastrouk
Answer 6 years ago
And you lose 5 leds out of 100 ? So what ? An LED can fail short circuit and open. You only need 400mA to run the LEDs this way.
A linear reg, like the 78XX series won't BOOST the current in anyway, if you only have 1A going in, you'll only have 1A going out
