281Views6Replies
Help setting up speakers to a Blaupunkt SHC-3200s Record player?
I have an old Blaupunkt SHC-3200s record player, that has a tape player and Radio. When I play a record, the music plays faintly through the unit. The speaker connection is two 2-pin DIN plugs, I have two of these plugs with cut off wires but am not sure how to connect these to a set of speakers?
Any help at all is much appreciated
Thanks
7 years ago
When you say "...the music plays faintly through the unit..." ...is that only when you play a record ? My guess now matches mpilch. The amp inside is broken.
7 years ago
One wire goes to one contact on the speaker and the other wire goes too the other contact. Nothing to it really.
Answer 7 years ago
Probably a silly question but above the output from the record player there it says 4-ohm. Do my speakers have to have the same rating?
Thanks
Answer 7 years ago
Yes and no. Commonly speakers are either 4 or 8 ohm. Either will work with a 4 ohm output.
Answer 7 years ago
Okay because I have connected various different 8 ohm speakers with no result.
Answer 7 years ago
Then i guess the internal amp isn't working.
