105Views6Replies
Author Options:
Help with MR16 bulb wiring on motorcycle! Answered
Hi, I'm from India and I own a bajaj pulsar 220 S that has a 35w 12v headlight and I recently bought an aftermarket enduro headlight to fix on it, but the problem is that the headlight I bought has two MR16 bulbls and each bulb has two wires coming from it both white in color, So I'm totally confused with the wiring thing, Should I solder one white wire with a red one from the motorcycles wiring socket and the other white with the black one of the ground socket? I'd appreciate if you could clear that up for me.
P.S - I'm a complete noob when it comes to electricals.
verence
3 years ago
Connect one wire from each bulb with the red wire from the motorcycle and connect the other wire from each bulb with black. Just as you said.
tushar2308verence
Reply 3 years ago
Thanks! I'll try it now, I thought MR16 bulbs are only compatible with AC wiring. Hoping I don't end up destroying the entire wiring, lol
verencetushar2308
Reply 3 years ago
For LED type there may be two options: LED bulbs for AC - the polarity (i.e. how you wire them) is not important. But as you only have DC half of the LEDs may stay dark - but if they have a bridge rectifier inside everything is fine - not sure if such exist. Or LEDs for DC, in this case the polarity matters and they should have +/- marked pins or wires.
verencetushar2308
Reply 3 years ago
No. As long as the bulbs are not the LED type but the standard (old-fashioned) halogen type, they don't care for AC or DC. As both wires from the bulbs have the same colour, they are mos probably not LEDs.
tushar2308verence
Reply 3 years ago
Indeed both the bulbs are halogen, but I was thinking to upgrade them in future, What's with the wiring of LED MR16s though? I'm curious to know about that as well, incase I upgrade to them in future..
