85Views4Replies
Help with Resistance formula.
How to find the voltage after adding a resistor with the resistance formula? For example I have a circuit that uses 0.975A and I add a 1000ohm resistor to it, if its powered by 220v main then according to V=IR what should be the voltage drop due to the resistor?
Best Answer 7 years ago
V=IR
It would depend series or parallel.
Parallel that resistor and that voltage it would be 0.22 A and 220 volt drop across the resistor.
in series it would be along the lines described by icing so it would be IR=V or
0.179 x 1000 = 179 volts drop across the resistor.
and
0.179 x 226 = 41 volts drop across the circuit.
These numbers are rounded.
Joe
7 years ago
RAC = V/I = 220/o.975 = 226 Ohms Impedance
Sounds like a Power Toaster
Now you add 1000 more ohms for a total of 1226 ohms
New AC Current = V/R = 220 / 1226 = o.179A
7 years ago
You need to know 2 of the 3 variables - Voltage - Resistance - Current. Then you can calculate the third.
Volts= Current x Resistance
V=Volts
I=Current (amps)
R = resistance (ohms)
V=I x R
so
I=V/R
or
R=V/I
7 years ago
What's the circuit ?
