513Views4Replies
Help with replica deadmau5 head?
I'm making a replica deadmau5 head and as trim around the ears and head, I want to add LED lights. What all will I need and how can I program them to change color by fading through the spectrum?
9 years ago
You will need an RGB (Red Green Blue) LED, 3 resistors, a micro processor, a switch, a battery and some wire.
You should get a starter kit and use it to program the micro on this computer.
A
Answer 9 years ago
Can you explain the micro processor and start kit please? What are they exactly?
Answer 9 years ago
A starter kit comes with most everything you need to hook up to and program a microprocessor. After you can just get the more of the BS1(costs less) .
The microprocessor (BS1) I recommend for your application can run 2 RGB LEDs at once off of a 9V battery and easily program from this computer. Don't forget to use six 56 ohm resistors.
Answer 9 years ago
Thank you very much!
