113Views16Replies
Author Options:
Help with some noise filtering? Answered
I've attached a file of a project I will build, but should I need some noise filtering capacitors?
Thanks,
BoK
aelias36
aelias36
Best Answer 9 years ago
Do you mind exporting your diagram in a jpeg or png file?
aelias36
aelias36
Answer 9 years ago
Screenshot, at least? Also, giving best answers will help you get better answers.
thegeeke
thegeeke
Answer 9 years ago
+1!
aelias36
aelias36
Answer 9 years ago
You're driving a microprocessor straight from a battery? Can you make the screenshot bigger?
Balls of Kevlar
Balls of Kevlar
Answer 9 years ago
yes, and I can't but I can tell you that it is an IC in the middle, the two top pins go to a battery, and all the other connected ones goes to a resistor then an led and then ground, that is it ;D
aelias36
aelias36
Answer 9 years ago
First of all, you shouldn't be running a microprocessor directly from a battery. What if the voltage is too high? Too low? What if the battery is accidentally reversed?
Second, what type of battery is it?
aelias36
aelias36
Answer 9 years ago
You don't need a cap.
Balls of Kevlar
Balls of Kevlar
Answer 9 years ago
put an answer if you want "best answer" ;D
steveastrouk
steveastrouk
9 years ago
Lots of questions, lots of answers, but no best answers - no more help from me.
Balls of Kevlar
Balls of Kevlar
Answer 9 years ago
sorry didn't know that, i'm new to everything, should I just do that to the most helpful question?
Re-design
Re-design
Answer 9 years ago
You probably got on his bad side when you told him he had to learn how to use capacitors.
