0Genius 470 6 years ago I was wondering if i could modify this code so i could control the led's with the serial monitor, but i don't know how, Could somebody help?int pin2 = 2;int pin3 = 3;int pin4 = 4;int pin5 = 5;int pin6 = 6;int pin7 = 7;int pin8 = 8;int pin9 = 9;int pin10 = 10;int pin11 = 11;int timer = 60;void setup(){ pinMode(pin2, OUTPUT); pinMode(pin3, OUTPUT); pinMode(pin4, OUTPUT); pinMode(pin5, OUTPUT); pinMode(pin6, OUTPUT); pinMode(pin7, OUTPUT); pinMode(pin8, OUTPUT); pinMode(pin9, OUTPUT); pinMode(pin10, OUTPUT); pinMode(pin11, OUTPUT);}void loop() { digitalWrite(pin2, HIGH); delay(timer); digitalWrite(pin2, LOW); delay(timer); digitalWrite(pin3, HIGH); delay(timer); digitalWrite(pin3, LOW); delay(timer); digitalWrite(pin4, HIGH); delay(timer); digitalWrite(pin4, LOW); delay(timer); digitalWrite(pin5, HIGH); delay(timer); digitalWrite(pin5, LOW); delay(timer); digitalWrite(pin6, HIGH); delay(timer); digitalWrite(pin6, LOW); delay(timer); digitalWrite(pin7, HIGH); delay(timer); digitalWrite(pin7, LOW); delay(timer); digitalWrite(pin8, HIGH); delay(timer); digitalWrite(pin8, LOW); delay(timer); digitalWrite(pin9, HIGH); delay(timer); digitalWrite(pin9, LOW); delay(timer); digitalWrite(pin10, HIGH); delay(timer); digitalWrite(pin10, LOW); delay(timer); digitalWrite(pin11, HIGH); delay(timer); digitalWrite(pin11, LOW); delay(timer); digitalWrite(pin10, HIGH); delay(timer); digitalWrite(pin10, LOW); delay(timer); digitalWrite(pin9, HIGH); delay(timer); digitalWrite(pin9, LOW); delay(timer); digitalWrite(pin8, HIGH); delay(timer); digitalWrite(pin8, LOW); delay(timer); digitalWrite(pin7, HIGH); delay(timer); digitalWrite(pin7, LOW); delay(timer); digitalWrite(pin6, HIGH); delay(timer); digitalWrite(pin6, LOW); delay(timer); digitalWrite(pin5, HIGH); delay(timer); digitalWrite(pin5, LOW); delay(timer); digitalWrite(pin4, HIGH); delay(timer); digitalWrite(pin4, LOW); delay(timer); digitalWrite(pin3, HIGH); delay(timer); digitalWrite(pin3, LOW); delay(timer);}
0steveastroukGenius 470 Answer 6 years ago No, you need to start with what I posted, after you've learned how to listen to the serial port.
0steveastrouk 6 years ago Yes, Here's one method, it will allow you to put any combination of 10 LEDs on or off at onceFasten all the LEDs to the Arduino pins. Read a number from the serial portif ( (number&1)==1) led1=1 else led1=0;if ((number&2)==2) led2=1 else led2 =0;if ((number&4)==4) led3=1 else led3 =0;if ((number&8)==8) led4=1 else led4 =0;if ((number&16)==16) led5=1 else led5 =0;if ((number&32)==32) led6=1 else led6 =0;if ((number&64)==64) led7=1 else led7 =0;if ((number&128)==128) led8=1 else led8 =0;if ((number&256)==256) led9=1 else led9 =0;if ((number&512)==512) led10=1 else led10 =0;There are other ways, but this is the easiest method for a beginner.
0Genius 470steveastrouk Answer 6 years ago Thank you for you answer, But could you explain a little bit more, because i'm only 13 and i just started using arduino and the coding.
0steveastroukGenius 470 Answer 6 years ago Do this in stages then. Take a look at the serial programming samples in the Arduino code and try them out. Make them turn on and off one LED first. Then come back and look how, if you enter a number from 0..1024, my code works.
0mpilchfamily 6 years ago Need lots more information here. What code are you using? What LEDs are you using? How do you have everything wired?
0Genius 470mpilchfamily Answer 6 years ago I'm using a led bargraph wired through pins of 2 through 11 of a arduino uno.
6 years ago
int pin2 = 2;
int pin3 = 3;
int pin4 = 4;
int pin5 = 5;
int pin6 = 6;
int pin7 = 7;
int pin8 = 8;
int pin9 = 9;
int pin10 = 10;
int pin11 = 11;
int timer = 60;
void setup(){
void loop() {
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
Answer 6 years ago
6 years ago
Answer 6 years ago
Answer 6 years ago
6 years ago
Answer 6 years ago
