540Views4Replies
Hi convert 12v signal to 220v?
Hello! I have a 12v signal and want to convert it to 220v, simply open the passage as a switch (progressive) and I have a 220V source, it would be like a relay but progressive.The signal is not always 12v it could be posible?
Thanks!
Best Answer 8 years ago
It is NOT just a matter of finding a bigger transistor, but rather using a different kind of device, called a TRIAC, and also driving that device in a different way. The amount of power that flows through a TRIAC switch is controlled by the timing of the trigger pulses that turn it on.
http://home.howstuffworks.com/dimmer-switch.htm/printable
http://en.wikipedia.org/wiki/Phase_fired_controllers
In contrast to the instructable you mentioned that controls a handful of LEDs using a single transistor
(https://www.instructables.com/id/Music-LED-Light-Box/)
the circuit for generating the trigger pulses for your TRIAC is probably going to be more complicated. I wish I could point to an easy example of someone who has already built the the thing you want to build, but the links that follow are the closest I could find:
http://www.circuitsonline.net/schakelingen/73/lichteffecten/4-kanaals-lichtorgel.html
http://pcbheaven.com/circuitpages/Voltage_Controlled_AC_Light_Dimmer/
http://pcbheaven.com/circuitpages/images/voltagecontrolledacdimmer_1262362194.png
Notice that, for both those circuits I linked to, there is isolation between the high voltage (220 V) circuit, and the low voltage circuit providing the control signal. In the first circuit I linked to the isolation is provided by a transformer. In the second circuit uses optical isolation (via the MOC3021).
Also I discovered a similar question asked to this forum before, and there might be some clues in that discussion too. Here:
https://www.instructables.com/answers/Trouble-out-putting-a-DC-current-to-AC-current/
9 years ago
1. Optoisolat your PC!! or you may say goodby to it.
2. You should/may be able to drive a standard dimmer circuit from the output signal and replace the traditional pot. This will give you a varying output at 220 volts proportional to the input signal.
Will need a lot of messing with to get it working Mains electricity is deadly! BE WARNED
9 years ago
Simple inverter. . . A
9 years ago
What do you mean by "progressive"? Like "proportional" maybe? Perhaps you want the 220V load to be 100% on when the input signal is 12V, and maybe 50% on when the input signal is 6V? And also 3V<=>25%, 6V<=>50%, 9V<=>75%, 12V<=>100%, and all points in between.
Like a voltage-controlled dimmer switch?
http://www.dimming.org/Technical/detail/749.html
Or something like that?
Answer 9 years ago
Yes Proportional i have a tip32 connected to pc audio and in 12v source i want to make work it to 220v
Thanks!!!
