161Views3Replies
Author Options:
High Pressure Shutoff? Answered
How do you make a high pressure compressor stop at 4500 psi without spending tons of money?
Hopefully adjustable between 3000 and 4500 psi.
orksecurity
orksecurity
10 years ago
The cheap solution is to use a pressure relief valve which vents off pressure above that. I'm assuming the rest of your system can withstand those pressures...
WARNING: If that valve fails, and you exceed the pressure tolerances of your system, it can fail catastrophically. Sticking pressure-relief valves used to take out large steam engines, explosively, on a fairly regular basis.
steveastrouk
steveastrouk
Answer 10 years ago
.....together with the local audience, and chunks of countryside. ......
