118Views3Replies
Author Options:
Home automation & Home door sequrity including one android apk file project available ??? Answered
Please help me for this project. how will be arduino program code , which pin are connect to apparatus to apparatus. please give me all description step by step this project implimentation.
Project planning:-
                  1.Home automation & Home door sequrity including one android apk file.
                  2. 4 Relay:   1. Blue led light.
                                2. Red  led light.
                                3. White led light for bath room using PIR sensor.(this light switch on/off only using pir sensor,
                                           because-wet hand electric shock on switch or, damged mobile display).
                                4. Fan using voltage regulator.
                                 note:- light switch on/off & fan switch & voltage regulataor incease/decrease including appk file.
                  3.Home squrity switch board on/off may be   a.display board on wall of house.
                                                              b. display in android apk file.
                  4.when open door with corect srquirty,then photo upload in memory card.if incorect password then a lout of sound.
                  5.when fire in house ,alarm using gas sensor. Room temperature, huminity show in display.
Apparatues:
           A: Led light on/off by mobile app.
                 1.ESP8266 Serial Wi-Fi Wireless Transceiver Module for IOT.
                 2.Generic(unbranded )4-channel relay control board module with optocoupler, 4 way relay module for arduino
                 3.Arduino Uno R3 ATmega328P ATMEGA16U2 Compatible with USB Cable.
                    or,xcluma Atmel Atmega 2560 Mega2560-16Au (16 Mhz) R3 Board+Usb Cable For Arduino.
                 4.Led light 3(Blue,Red,White for Bath room),Motor Fan.
                 5.REES52 REES_2 Bread Board or Solderless Pieces Circuit Test Board Project Board.
                 6.Jumper Wires Male to Male, male to female, female to female.
                 7.Generic KG001 HC-SR501 PIR Sensor Pyroelectric Infrared Module 2pcs(for bath room & door open).
                 8.Adraxx LM7805 7508 Positive Voltage Regulator IC, 5V 1A.
                 9.Resister 1k ohm.
                 10.REES52 MQ2 Arduino Compatible Gas Sensor, Methane, Butane, LPG, Smoke Sensor.
          B: Home sequrity.
                 1.Quantum QHM495LM 25MP Web Camera.
                 2.SanDisk Ultra MicroSDHC 32GB UHS-I Class 10 Memory Card With Adapter.
                 3.REES52 621033926893 Universial 16 Key Switch Keypad Keyboard Fit for Arduino by REES52.
                 4.Silicon Technolabs 20x4 Line LCD Display With Blue backlight HD44780 for ALL Arduino,Rasp Pi,AVR,ARM,8051 (Blue).
Software:      1. Arduino-1.8.5.
               2. wampserver & notepad++ (for php web page).
               3. Android Apk file.
please help me for this project. how will be arduino program code , which pin are connect to apparatus to apparatus. please give me all description step by step this project implimentation.  i will waiting for you.
Tags:wind
iceng
iceng
3 years ago
First person to provide a semblance of a flow chart...
Sad OP has no hardware or software skills...
Downunder35m
Downunder35m
3 years ago
Sure, you are meant to do a project as it is evident by the list you posted.
But being a project assinged to you means that you do the work to get it going!
If you want someone to do it for you be prepared to pay at least $80 per hour.
With the specs given I would guesstimate that a pre-payment of around $500 would suffice to get going.
All up it might be around $800 when finiished.
steveastrouk
steveastrouk
3 years ago
You'll have to wait a long time for someone to do all that for you for free.
