4771Views19Replies
Author Options:
How Can I Make My Sled Faster Without Spending Too Much Money? Answered
Ok, I just got a foot of snow and I want to know how to make my sled faster for little money.
p.s. I have a flat bottom sled, not those complex things with like 5 skiis, just a plain old flat bottom sled well it is actually an inch of foam, then a thin layer of slick plastic
mikeasaurus
mikeasaurus
Best Answer 12 years ago
They wax the bottom of skis and snowboards for enhanced performance, that would be a great place to start and it's relatively cheap too!
If you're looking for an even more budget way to do this you could always grab a can of cooking spray and spray away, reapply every hour or until you run out (I can hear the environmentalists screaming already..)
Thelonelysandwitch
Thelonelysandwitch
Answer 12 years ago
I forgot to mention that, But I use car wax, and it helps. dang u are fast at responding
PKTraceur
PKTraceur
Answer 12 years ago
Silicone spray the bottom, this may help. Otherwise, wax it! -PKT
PKTraceur
PKTraceur
Answer 12 years ago
No, because it will dry within a few minutes. It pretty much the same thing as waxing, just slightly.... less? More? Try it out.
AnthonyW44
AnthonyW44
5 years ago
Depending with it's made out of (if its wood or some type of plastic) try cutting grooves lengthwise across the bottom, should give you a bit more speed and stability.
mcald
mcald
11 years ago
lose 5lbs
mcald
mcald
Answer 11 years ago
i was just joking but if you sit closer to the back it will raise the front wich sould help
Junk_Wizard
Junk_Wizard
12 years ago
an even cheaper approach... find some sort of cooking spray and spray it on the bottom of the sled, usually lasts a short time but does help... this also works for shovels that get snow stuck to them a lot.
Junk_Wizard
Junk_Wizard
Answer 12 years ago
Yes, that's where the 'usualy lasts a short time' comes from 3-5 runs on a sled, its good for packing down the track if you discover an unabused hillside...
Thelonelysandwitch
Thelonelysandwitch
Answer 12 years ago
ok, ill try it when it snows again, we just had 2 days of 70* weather and the foot melted.
tesla314
tesla314
12 years ago
As a kid we used to speed up our (metal) slide by rubbing it down with waxed paper. Might be worth a shot. Same idea as the car wax, but might be more likely to have it already.
psymansays
psymansays
12 years ago
Get some used skis from a thrift store for maybe $10, and bolt them to the bottom of the sled. Skis will go faster than the sled will, in most snow conditions.
