4515Views50Replies
How To Create Frequency Specific Microcurrent?
Curious if some of the electronic gurus might have the answer to this.
I am looking to build a two channel (A/B) microcurrent (allowing from 20 - 600 microamps) with selectable frequencies ranging from 3 to 970 Hz). This is based on a medical device that I'm looking to replicate. I've figured out some of this but again, considering the wealth of knowledge here I'm sure some would know the best way to build this. Oh yeah, I figure using a rechargeable battery which could be whatever voltage is best recommended.
So what do you think???
6 years ago
I posted this a while ago but not seeing it here. Below are images of the existing circuitry on a commercial FSM unit. Not sure if it gives any insight but here it is...
Reply 10 months ago
Yeah . . I've got that book. It's a little outdated to the technology we have now.
Answer 6 years ago
By the way, this commercial unit uses only a 9-volt power source and my understanding is a single battery lasts literally weeks and weeks since the output is so minimal.
1 year ago
Hi,
Is there anybody who can build for me a microccurrent like explained in linkes below,i can buy him if it is not expensive and working well?it is for health
Thanks
https://frequencyspecific.com/microcurrent-experim...
https://www.timewaver.com/
Reply 10 months ago
Did you find what you were looking for. I'm too looking for such a device. Holler back.
1 year ago
Hello friends I am much interested in building frequency specifics microcurrent device and I am a doctor by profession using FSM with great great results . Iceng if you have peripheral neuropathy, then this device is is definitely for you, also according to my medical knowledge any tens device with milicurrent output will not help.
OK so one of my friend gave me a clue how to build the device.
I am attaching pics I have and the list.
Guys please guide me
This pmw generator is good for FSM (I think)
1.It has 2 channel output
2.frequency range is good for fsm
Here is the link
Rs. 80.55 15%OFF | Micro USB DC 2CH Adjustable PWM Signal Generator Duty Cycle Pulse Frequency Module Digital LED Display Tube DC 5V 12V 24V DIY
https://s.click.aliexpress.com/e/mjtpuP6g
Now I need to convert the current output to micro ampere
What I need for that
Microampere meter/digital multi meter?
Or we need a variable resister
Also to check if the current output is correct, how can we check
Reply 10 months ago
Howdy . . I'm also a doctor and looking for an less expensive
Microcurrent device. What did you come up with? I'm very interested.
Reply 1 year ago
Hello Doctor and thank you for your advices
I am searching for an affortable fsm for me and my Mother,family....
i have a tens and like you say it does nothing
10 months ago
Howdy . . . did you finally get what you wanted? I'm in the same boat and am looking for a inexpensive variable frequency micro current device. Holler back.
1 year ago
Instead of just one frequency I built a generator using 4 555 with variable frequencies running on 18 volts and I got tired of messing with a battery so I switched it to ac using 12 volts since ac runs both directions and would burn up the chips I put a converter in. I realized how difficult it would be to get the voltage needed to realize my goal with just one circuit that's why I added the other three. I combine the voltage in a hand held piece of copper that is separated in the middle with an insulator, I think what your trying to achieve might be similar to what I'm doing so I hope this helps.
2 years ago
how about using Bob Becks micro-current pulsar? I built on years ago and it's very effective for dispersing agglutinated red blood cells. I'm trying to see if it could be converted to an micro-current facelift device. Here's a link to the plans: https://www.bobbeck.com/pdfs/build-your-own.pdf any ideas?
Reply 1 year ago
Hello estabano,
Does your spooky device work like an fsm or you have to add somes components?because i search an affortable fsm that is works well.
thank you
1 year ago
Hi there,
does somone has seen my first comment
2 years ago
that you’ve been sharing and discussing here.
I’ve been following the Frequency Specific Microcurrent (FSM) discussion here over the last year or so as well as trying some other routes to create an FSM equivalent device. Despite figuring out some of the basics I’m still quite confused by many aspects of the discussion here as I imagine many other readers without a formal electronics education or similar background likely are as well.
While I’ve been gradually working my way through the Charles Platt Make Electronic
books and struggling with Practical Electronics for Inventors, etc. I still find even basic circuit design pretty confusing.
Any help in clarification and additional details that you can offer to someone
like myself who really doesn’t seem able to ‘get’ electronics
without fairly complete details would be very much appreciated! I
keep studying what I can and hoping that something will just ‘click’
in my understanding – but so far no luck. I’ll keep trying but
at the same time would really like to have access to an FSM
equivalent device as it seems it would help with several health, etc.
difficulties of myself and others. So I’m really hoping for a
temporary short cut in my learning process to figure out a few last
technical details that while probably really quite simple still keep
baffling me.
I’ve been trying to keep my FSM attempts as simple as possible by using
pre-made modular-like components whenever possible. As things stand
now I have a few programmable frequency generators (mainly via the
Spooky2 system) that while they cover the full range of frequencies
and wave forms needed for FSM their output is only about 5 volts or
so per channel and from all that I’ve found the voltage through the
electrodes into the body needs to at least have the potential
of 45V to consistently push the current/signal through the
body/variable skin resistance.
So my two main essential requirements at this point are still:
1.) to have a way to boost the 5 volts up to 45 volts (through each of the two channels) – and if I understand correctly that’s what your opto-isolater-based driver design suggestions to Dovid G are designed to help with- and
2.) to limit the current that the user receives to the 20 to 600 microamp range
that is the standard range considered optimal for FSM.
I don’t know if the 2.) current limiting goal is already
automatically taken care of by the design options you suggested for
Dovid otherwise – for now I have a variable box resistor board
with a LM 334 Current Limiter-? - (an approach suggested on the Spooky2 Forum board where there's a somewhat similar FSM-related discussion) but ultimately I’d like to have a built in potentiometer as part of the final PCB /circuit - in order to more conveniently adjust the output Amperage.
????????? a decent way to limit the amperage in this case ????
I’ve purchased the ILQ2 Optoisolator part included in your
design but don’t understand what the U5 4049 part is. Is it an
OpAmp or something else?? - and how would I order it or under what
name – from Digikey, etc. or otherwise?
Also could you please offer some basic help or advice on how to translate the
diagram(s) /schematics for the drivers you offered to a
breadboard – and ideally or more importantly to some kind of a PCB
layout? I still haven’t quite succeeded in learning to use an
appropriate circuit simulator program or otherwise finding someone
local to help with these steps. Thanks.
Additional Power source(s)?
In regards to the diagrams of your driver design – am I correct in guessing that
they’ll require some additional power source – like a bunch of
batteries hooked up to a buck converter or two. Like groups of four
AAs or so? Any suggestions. - also what settings ideally? 45
volts on each?? - and I’m not sure if I can guess how any such additional
source would be properly wired in to the driver schematic/PCB.?
Additional need for Current limiting ?:
If there is an additional need for current limiting for the final output through the
electrodes into the body – beyond what your schematic automatically
provides - how would you suggest best accomplishing that and is it
reasonable to attach a potentiometer or other device to make it
easily adjustable as well as maybe an Led set up to visually show or
suggest different intensities? - and even to wire in a little
digital or analog read-out of current levels.
Thank you very much again for your sharing and advice here. I hope I’m not asking
for an annoyingly in-depth level of clarification in regards to your
designs. I may just be unusually dense when it comes to
understanding electronics – but I really really really do want to
know how to make one of these devices in a relatively affordable
manner - for myself and for anyone else interested. ( Eventually I'd like to be able document something that a person with near beginner level
skill could comprehend and assemble for under $300 - I’m hoping.) I've
already spent quite a bit in my clumsy attempts to assemble the
proper parts and learn enough key electronics concepts to make such a DIY FSM device. So again your help in making these details clear will be very
appreciated.
Sincerely,
Steve
2 years ago
I found this looking to make a FSM myself too. Is there perhaps a way to use a soundwave software to choose the amps, frequency, and channels, and just output it to a USB chord with the end cut or a headphones cord?
2 years ago
I know this is an old post, but has anyone built a FSM machine successfully since?
Answer 2 years ago
I don't know of any (microamp) FSM having been built.
Currently I'm back tracing a quad multi program Tens (milliamp) like machine in my spare time.
You just joined what is your skill set and application (only curious :-)
Answer 2 years ago
Oh I’m only a hobbyist. I’m not the most experienced either, but I’ve built a few things in the past (stereo speakers, radio guided toy car, a bob beck machine (which is a much simplified version of FSM I guess)... I like to open my broken appliances for fun and see if there’s anything I can do to make them work again)
As for my interest in FSM, I have a condition, nothing life threatening but some days the symptoms are so bad that I just want to die. I’m at the point where I just try whatever to see if I can feel better, even for just a while.
Answer 2 years ago
I too have a condition.. Mine is peripheral neuropathy and lately i have tried a Capsaicin slave which due to the nature of of the hot pepper overwhelms the nerves that cause pain to the point of serene non-feeling for hours of time.. Hope you can find relief..
Attached is a very simple to make Low Power "Tens" circuit for you...
Answer 2 years ago
Thanks! I'll have a look
3 years ago
Here are illustrative pictures, first four are Clivite Spark Pump..
3 years ago
3) I think I understand what you meant: do you mean that since you have the RLim resistor in series with the load, any variation in skin resistance will be negligible? If so, do you think 75 K is enough? My understanding is that skin resistance can be up to 1M.
Answer 3 years ago
Be creative measure your own skin resistance..
I did threshold of feeling AC current between two fingers..
Most people in my office could detect 1/2 to 2 ma current between adjacent fingers..
With an electrician who had to wet his finger to stick it in a lamp socket to feel anything to my Japanese friend who could detect 50 uA AC.
3 years ago
2) I am designing a PCB to deliver FSM and I have a 9VDC supply, so in order to drive 45VDC I thought I would need an SMPS from 9 to 45
3) Just to check that I understood you correctly, do you mean that Rlim in series with the high output resistance of two BJTs is high enough that makes any change in the load negligible?
3 years ago
1) The circuit is being changed from 5V to your 9V. The CMOS inverter has a lower drive current, putting 3 gates in parallel will guarantee you drive the isolator LEDs properly...
2) This is a microcurrent device and I realty don't know what your SMPS is designed to do..
3) You understand the application correctly... The NPN Vce is limiting the high voltage and high resistance to properly make all skin resistance values compatible..
if you go and drive a mosfet bridge you could reach 300V and a comparably higher series resistor...
BTW the sticky electrode pads do reduce you finger high skin resistance substancially.
3 years ago
Thank you iceng for posting!
I have a couple of questions
1) you wrote “Today I would change the 150 ohm to 330 ohm using 3+3 parallel CMOS gates at 9VDC....” Why would you do that? What is your reasoning?
2) Assuming I use a boost SMPS to get my 45 volts, how much current can I draw from it safely
3) I’m no expert, but I would think that one problem with applying FSM to the human body is that the skin resistance has a very large range. Can we engineer some kind of feedback into the driver so that at the very least, a consistent DC is always running through the load, between the load being say, 15 K and 1 M? (It would also be nice to make sure the AC also has a constant amplitude). Although, I think you meant to clarify this by writing “Remember the high voltage and high resistance acts as a constant current regulator for skin resistance variations”
Thank you so much!
3 years ago
DavidG asked me by PM for a driver...
Here are two drawings (you need to click to see the whole image) of the same schematic, whichever is easier to visualize.. The LOAD is your body which gets controlled low current AC and uses a single Quad opto-isolator.. Today I would change the 150 ohm to 330 ohm using 3+3 parallel CMOS gates at 9VDC....
Remember the high voltage and high resistance acts as a constant current regulator for skin resistance variations.. I don't remember the NPN emitter collector withstand voltage which you want to use... And the FQ was low under a 1000 cps
Too bad no one is left to give a best answer :-/
4 years ago
Hi there, I'm wondering what happened on this thread?
Did pletchman ever complete his project!?
I want to build one now too!
6 years ago
I picked up a book "Build The Micro-Stim" by Reginald W. Davis which actually gives the schematics to build one of these things. One thing -- he uses a 9volt battery to power the LED display and a 45-volt battery to power the unit. I'm curious why he chose or needed to use a relatively high voltage. Also, if I were to use a 9-volt as the power source how would that impact the generation of the microamps and the pulsating frequency??? Any thoughts?
Answer 6 years ago
Feeling guilty about not providing a circuit for you. Now I recall the old design knowledge.
A high voltage allows a designer to make a simple constant current by requiring a high series resistance compared to the small irrelevant skin resistance variation. This also works as there are no microamp regulators that I could find and looking at using an opamp current fractional gain structure was unstable.
Answer 6 years ago
No problem. I appreciate and respect your time and expertise. This is more of a pet project so I've got no deadlines or anything. So I think I understand the high voltage appeal but I assume this isn't necessary since the commercial variant of this device only uses a 9-volt battery.
Also, in Davis' book he gave an updated version which allowed variable frequency via a potentiometer. In the original design he used four IL-74 optical couplers to reverse current flow but now opts for a 2506 quad opto-coupler. Below are the images of his complete circuit layout
So I'm thinking about building a variant of his design and I'd like to use a li-ion battery or something small and portable. If you could help me through integrating his design with a lower voltage battery that would be awesome.
Answer 6 years ago
Yet as I understand the 9v commercial still has high voltages presumably from some inductive kick-up inverter ?
Keep in mind I could not find a satisfactory semiconductor microamp regulator for skin resistance variations..
Answer 6 years ago
Hmmm -- the photos I provided for the commercial unit show all the inner workings. Do you see what they use to invert to higher voltages?
Answer 6 years ago
Found two inductors L1 & L2, one of which could be used to program an older flash memory the other could be your skin HV.
Answer 6 years ago
I see those. This unit does have flash memory (very poorly designed and still in use) so you're likely correct on one. So I assume you are saying they implemented an inductor to compensate for any changes due to skin resistance. So you're saying with a higher voltage like Davis' used in his version (45-volt) there isn't a need for this "buffer"
So what if I wanted to use a very efficient 3.7v Li-Ion battery for size and portability and the ability to keep it charged for when needed. What additional components would I need to use to make sure it worked?
Answer 6 years ago
What I was offering is any battery can use an inductive element in a kickback inverter circuit to make a higher 40 to 90 voltage that is then regulated stable enough to make your constant skin current feasible.
Say 50 VDC 100 uA needs a 1/2 megohm (500,000 ohms)
Skin resistance is known to vary from 1000 to 20,000 ohms while an individual may only range 2000 to 10,000 ohms or +-4000 ohms
A change of 4 of 500 would be 0.8% variability all because of a higher voltage.
Answer 6 years ago
Ok. I've been making progress on working this out. I'm looking at either an oscillator circuit using the venerable 555 timer chip or possibly the quad optocoupler suggested in the Reginald Davis book. However, I've also come across using a signal generator to achieve the desired frequency and this seems much more flexible and (equally important) programmable to work with. I'm a little unclear if there are any reasons I can/can't integrate a signal generator in lieu of the oscillator to generate the desired frequency as needed. Please impart your thoughts and wisdom.
Thanks in advance as always.
Answer 6 years ago
The 555 can easily deliver twice the frequency 5 to 2000 hz divided by a flip-flop deliver a 3 to 970 hz square wave to your opto current H Bridge.
Only the first 555 period will be a little longer as the timing capacitor first charges from near zero volts.
Answer 6 years ago
The only problem with the 555 is I've got to use a slew of capacitor/resistors to get each of the combinations. I don't want to use a rotary potentiometer. I've looked into the 256-bit digital ones but, again, if you look at the AD9850 or AD9851 signal generator can get all frequency ranges precisely and pretty cost effective and since its software controlled I can set it up to run through an Arduino type board. What do you think? One concern or question is if the 35-volt input will be an issue and also is there any functional difference in the frequency created by the 555 timer oscillator circuit verses the DDS signal generator?
Answer 6 years ago
Fine get your frequency using what you want. I only mentioned the 555 as a simple fq gen.
The 40 VDC is only applied to the optoisolators.
Answer 6 years ago
how do you apply the 45-volts to the frequency after the 555 timer or signal generator? The output on the ad9850 signal generator is only about half a volt and I know 555 timers don't allow higher current through them either. So what's the next step after I create a frequency? Thanks
Answer 6 years ago
So would the boost converter by applied to the current AFTER the frequency is created/established. Does it get changed going through the boost circuitry? Also, your skin tolerance information was very useful. Would you suggest adjusting the anticipated microamp output to take into account the typical resistance value for skin? In this case I'd be using conductive gel and leads so I assume the resistance would be minimal. But say the conductive gel method has a typical 3,000 ohm resistance (might be less not sure). Would I assume that additional resistance into all my microamperage calculations. What do you think?
Also, I am not married to a signal generator vs the 555 timer. I just thought from an ease of use standpoint it seems much easier than calculating every R & C amount for 1000 frequency settings. Please let me know if you feel I'm missing something or have a reason to doubt a signal generator in this application.
As always thank you for your wisdom and input
Answer 6 years ago
got it. I worked in a boost converter to get 35v to work with.
Answer 6 years ago
Great !
Answer 6 years ago
In Reginald Davis' version his complete parts lists was the following:
6 years ago
OK here is the first part, a sine wave phase-locked-loop that can operate on a 1000 to 1 frequency range.
http://www.maximintegrated.com/en/app-notes/index....
All that remains is to add an adjustable current limited 25V DC source and a push-pull output, most likely complimentary mosfets because bipolar devices would inject base-emitter currents in excess of 20 ua.
Will see if I can get a design for you.
6 years ago
hello ICENG
Glad to have someone with your wealth of knowledge taking a peek at this "challenge"
1 OP-AMP no skill but I am familiar with them
2 RMS or peak I presume RMS but don't think it's overly critical
3 Yes, skin contact via gel-based conductor pads at two points for channel A and two points for channel B
Answer 6 years ago
http://www.tenspros.com/
sounds like what your looking for?
Answer 6 years ago
TENS units operate on milliamperes and a more narrow frequency range. frequency specific microcurrent runs on microamps and a broader frequency range with two channels instead of one as well. Thx
6 years ago
HI ! ... Long time no hear and were a couple years older.
How skilled are you with op-amps ?
The microamps are RMS or peak ?
What is the load the current flows into ? ... Skin ? .... resistance ?
A
