66Views2Replies
Author Options:
How can I build a 150MHz clock? Answered
HI, I need a clock oscillator of 150 MHz for a project. This oscillator must be built up from components and ics and not from a microcontroller.
so i have tried to simulate many quartz crystal colspitt oscillators, only I am unable to build high frequency ones.
Orngrimm
Orngrimm
1 year ago
150MHz is in a nasty area of HF. High enough to have all sorts of leakage and RF-interference and -immunity-problems. Yet, still not high enough to restart having it behave like DC again (high GHz, THz and up).
Simplest solution: Take an oscillator ready to ose off-the-shelf:
https://www.mouser.ch/Passive-Components/Frequency...
But be aware that you have to know a thing or two about how to handle and use such oscillators...
Jack A Lopez
Jack A Lopez
1 year ago
You know, you can buy a crystal oscillator as a single component.
Typically, it is little metal box, usually less than 20 mm on a side, and it has three terminals: ground, Vcc, and clock out.
I can point to one I found in Digikey's catalog, here:
https://www.digikey.com/product-detail/en/kyocera-...
with link to a data sheet, here:
http://global.kyocera.com/prdct/electro/product/pd...
It wants 2.5 V, or 3.3 V DC, at 21 mA (max), and has a CMOS output, presumably oscillating with a frequency very close to 150.0000 MHz.
The only downside is, it is one of those tricky little surface mount packages.
I prefer ICs with pins made to drop through holes, because that kind are easier to plug into muh breadboard.
