120Views10Replies
Author Options:
How can I connect a thin sheet of metal inside a circular metal container? Answered
Without welding because the container and metal sheet are kind of too small to weld. I'm thinking of soldering them (I'm desperate) but I'm not sure if it will be effective. There will also a process where I will put the container in a boiling water bath so it is not possible to use adhesives that will melt. I know this sounds weird, but it's a school project. Thanks!
steveastrouk
steveastrouk
5 years ago
3M VHB tape. Just get the high temperature grade
rickharris
rickharris
5 years ago
Unless you have some other issues use tabs and rivets and seal the joint with silicone sealer.
iceng
iceng
Answer 5 years ago
A great example of resistance spot welding which is a misnomer just like explosive welding.
First picture by HarnessedDevilry
WilnaC
WilnaC
5 years ago
Is steel adhesive, the one with two somethings that are being mixed, effective? We're trying to combine a metal roof sheet (it's thin only about a few mm) and a stainless steel container. I'm sorry. I know this sounds ridiculous but if I provide you more information, you'll probably think I'm nuts. Without bolts...
iceng
iceng
Answer 5 years ago
Sun heating and moon cooling twice a day will separate a solid two part adhesive due to daily metal expansion and contraction.
That is why motor homes use a tar like substance to join overlapped metal walls.
Yonatan24
Yonatan24
5 years ago
A Silicone Ahesive can work
Yonatan24
Yonatan24
Answer 5 years ago
They have an ultra high adhesion, Are water-proof, and Heat resistant
Josehf Murchison
Josehf Murchison
5 years ago
Tin, steel, or copper, soldering should be fine as long as it is not used for food, the led in the solder will leach out.
The smaller the part the easier to solder.
Aluminum or stainless steel you need special equipment.
rickharris
rickharris
5 years ago
What metal
How thick
What reason do you need to fix it.
On the basis of your information so far:
Nuts and bolts
Rivets
Brazing
Soldering
Epoxy glue
Slots and flaps
magnets
