1027Views18Replies
How can I convert a 17vinDC to 20vout DC?
Hi Fella's
I was wondering again if there is any schematics here that I can use to convert a 17in to 20v out DC-DC converter? Kindly send me a link please.
TiA
Hi Fella's
TiA
9 years ago
(Another cryptic "try to guess what it is that I'm talking about" question)
What is this 17V thing?
What is the 20V thing?
What are you trying to do with them, i.e. what is the problem?
(I hope this is not a "I have this many LEDs..." thing)
L
Answer 9 years ago
Hi Lemonie,
I have a solar panel that has a 17v output but in order to use it to charge my laptop I would need at least 20v output. So, I need to step up the 17v to 20v but the problem is I don't know how to do it nor do I see any of it in the DiY shop. I would like to seek your help if you could help me so that I can convert my Laptop to a Solar Laptop because in my provincial house we don't have a continuous supply of electricity.
Do you have any schematics or suggestions how I can do it?
Thanks
Answer 9 years ago
It is a great deal easier to Buy or build a second solar panel
and put in series with the first !! See the image.
A
Answer 9 years ago
Hi Iceng,
The problem is I only have 2 types of solar panel one has a maximum output of 17v and the other is 9 volts if that so I will have 26v should I connect it in series. My Laptop requires 19-20v input, won't it burn my laptop if I connect a 26v?
Or, Can you suggest How can I lower down that 26 volts to the desired voltage?
Thanks
Answer 9 years ago
Covering part of the array will let you reduce the total voltage.
A
Answer 9 years ago
Iceng,
Honestly I don't want to do it that way because i could still have the potential to use that 9 volts instead of covering it. But, I would request if you have any other suggestion or Idea where I won't have to do as you say? Cause, I think there would be a lot more potential use instead of covering that panel and reduce its productivity.
I can do some works if you have a design.
Thanks
Answer 9 years ago
How much current does your laptop need at 20 VDC & i can regulate
from 28 to 20.VDC
A
Answer 9 years ago
Hi Iceng,
One of my laptop requires 19v 3.2A and my smaller one needs 19v 1.58 A. I would like to ask for both since I use them both on the province.
I could have different schematics that I can work with should you have the design or it would be best if we can make it in one. I really appreciate your help with me on this and I am happy to have someone like you to help me with my problem.
Thank you again in Advance.
Answer 9 years ago
The power needed by your lap top is over 60 Watts
Assume 80 Watts to up-verter to 20VDC.
Your solar panel must be approximately 32" x 32" area with an
optimum current 4.5ADC @ 17.5 VDC and weigh 16 LBs with the
support frame.
This is the minimum you will need to power a small up converter to power
the 61 watt lap top ( 19V 3.2A ).
If you have such a panel let me know and we can continue.
A
Answer 9 years ago
Hi Iceng,
Any word about my request?
Thanks
Answer 9 years ago
Here is an inverter I simplified for only your smaller 30 watt lap top from
the 50 watt solar panel at full sunlight. Can not do 80 or 60 from a 50 w.
Here is a 30 Watt inverter circuit using minimum number of components.
Here use a CD 4047 IC from Texas Instruments for generating the 100 Hz
pulses and two 2N3055 transistors for driving the load. The IC1 Cd4047
wired as an astable multivibrator produces two 180 degree out of phase
100 Hz pulse trains.
These pulse trains are preamplified by the two TIP122 transistors.The out
puts of the TIP 122 transistors are amplified by four 2N3055 transistors to
drive the inverter transformer.The 20V AC will be available at the
secondary of the transformer. Nothing complex just the elementary
inverter principle and the circuit works great for small loads like a lap top.
Notes:
Design tips:
Answer 9 years ago
Iceng,
Do I need two solar panels for this since now I only have one 50w solar panel. And this is really a very good stuff I will make this as soon as I am back from my vacation.
Many thanks
Answer 9 years ago
Yes, but that inverter was modified to power just the low power lap top
when you double the solar capacity, I have to make a more powerfull
up-verter (probably a mosfet higher fq toroid design)... A
Answer 9 years ago
Can you rewind a primary ?
Since the output is only 20 volts winding is not critical at all.
Your specifics voltage and current requirements precluded a boost
device or a standard transformer.
It may be easier to wind a toroid transformer, but one must have the core
B-H curve to calculate.
A
Answer 9 years ago
Iceng,
I have 50watt solar panel that has 17v out and 2.87A 670mmx630mm, do you think this could do it? I could still acquire one more of this.
Thanks
Answer 9 years ago
Hi man - thanks for the reply. I was partying yesterday and now I'm very tired - stick with iceng he knows what's what...
L
9 years ago
I won't provide schematics, but I will suggest a method.
You can use a voltage doubler to achieve 34V, from which you can step down to 20V.
9 years ago
That's a very narrow range to try and boost. What are you actually trying to do ?
Steve
