20182Views20Replies
Author Options:
How can I cut geode, is it possible to cut with a dremel? Answered
Basically, I want to try and make jewelry with a geode stone I bought. But when I tried to cut it with a tungsten carbine cutter, the stone turn red and it smell like some burnt stuff. It also happen when I tried to grind with aluminum oxide bit. My geode crystai Is quite thick. Please tell me how can I cut/grind the geode?
Vyger
Vyger
Best Answer 6 years ago
A dremmel is not designed to use with water. Water is the best lubricant that you can use for this type of thing. It also cools everything so things don't get red hot.
If you cannot afford any of the sugested tools you might need to pay someone to cut it for you.
iceng
iceng
3 years ago
Work in water. Available at harbor freight...
Geodes are available to find or buy in and around Primeville OR..
AndyS227
AndyS227
3 years ago
After 2 years, the OP likely has found a solution, but this might help someone else down the road. An angle grinder worked well for me. Held geode in a bench vise during the cutting. Then used a metal file to clean up the edges.
loompiggytutorials
loompiggytutorials
6 years ago
What I would do is lay down some newspaper, wrap your geode in a damp towel, and give it a few taps with a hammer. I did this and it turned out fine. Just make sure you hit it in the middle. Hope I helped! =)
steveastrouk
steveastrouk
6 years ago
If you have a flexible drive for your dremel, you could use that underwater, or with a drip into the cut. A dremel is a toy cutter, and you must load it very gently.
An alternative is a grit-edge hacksaw blade.
iceng
iceng
6 years ago
I use an electric tile cutter with a water tray
steveastrouk
steveastrouk
Answer 6 years ago
Where did you get the geodes ?
iceng
iceng
Answer 6 years ago
There are sites where one can collect geodes every where in the US.
Many fields within a 2day drive.
Shizen
Shizen
Answer 6 years ago
I can't afford that.
mpilchfamily
mpilchfamily
Answer 6 years ago
Your best option is to go to a tool rental place and rent the tile cutter.
iceng
iceng
Answer 6 years ago
Go to a construction site and ask the tile layer to let you cut your SiO2 Silicone DiOxide which is the major constituent in geode crystals.
Josehf Murchison
Josehf Murchison
6 years ago
You can use the tungsten carbide cutter with water or the aluminum oxide bit with water or a diamond saw blade with water.
You must use water or you burn the stone or crystals instead of cutting it.
How are you planning to polish the stones after you shape them.
Have you seen my Hobby Tumbler?
https://www.instructables.com/id/Hobby-or-Case-Tumbler/
Joe
Shizen
Shizen
Answer 6 years ago
I'm sorry, I'm used a fiberglass cutter, also can you tell me how should I cut and submerge my geode without ruin my dremel?
Josehf Murchison
Josehf Murchison
Answer 6 years ago
I have 3 dremels
1 air powered
1 electric with a fixed flex cable extension.
and 1 electric you can swap from straight dremel to an extended flex cable.
My dremel has an attachment that has a flex extension that keeps the motor away from where I am working.
Joe
Burf
Burf
6 years ago
You'll need a diamond impregnated blade and most often, lots of water to cool and lubricate the blade.
Shizen
Shizen
Answer 6 years ago
Too expensive, cheaper method please.
steveastrouk
steveastrouk
Answer 6 years ago
How much is a blade in Vietnam. Here they are probably about 10 GBP/ 15 USD
Shizen
Shizen
Answer 6 years ago
I got my tool when I was in LA, since I'm back and VN don't sell them, I don't think it is an option
steveastrouk
steveastrouk
6 years ago
The traditional method would be grit impregnated string, in something like a saw frame. Incredibly slow - but very cheap. The grit can be sand.
