5949Views18Replies
How can I heat my swimming pool early? Although I live in the south (NC), my pool is shaded by neighbors' huge trees.
It takes 2 months to get to a good swimming temperature.The pool is 16 x 30', depth varies from 3' to 9'.? I have a solar blanket which will keep the heat in. But it will also add trash(grass and gravel) if I put it on and take it off everyday.
10 years ago
I was thinking electric. What if you buy 6 sq. ft. of this... http://www.contractorsdirect.com/Laticrete-Floor-Heat Maybe wrap it around a 3 ft. long piece of 6 in. pvc pipe. Wire it to an extension cord. A thermostat. Plumb a simple inlet and outlet on the pipe. Then build or even find a box this unit will fit in. "Possibly bury it in the yard." If in a box fill the box with some type of insulation. Never power up the mat when : A) you are In the pool. B) the pump is not on. C) you are not home. If it runs safely you could forgo C) after many hours of use. It should not cost more than $80 to $100 I may try this...
11 years ago
cut down your neighbors tree, it's easier to ask for forgiveness than for permission : )
11 years ago
take an old hot water cylinder, cut it in half (you can do that with an angle grinder) plumb one end to a pump ant the other to the pool now light a fire in it and your done. i live in england and if you use coal all around it it works a treat. dont turn it off till the fire is out though or you can melt solder and other things, this also loks pretty good in the evening. stick a grate over the top and you have a bbq aswell how cool is that
12 years ago
This sounds feasible. There would need to be a weight system. Even with the cover that I use in the winter to keep out trash and leaves, it is a challenge to keep in place sometimes. It lays on the surface of the water, overlaps by about 24 inches all around. I use planters and concrete blocks to weight the edges. These are not something I would be able to move daily. However, I'm getting a picture of your basic idea and seeing possibilities! Thank you. Come swim anytime!
12 years ago
Hey some thing like this Is fairly easy and you can do it for about under 5$ Note if you dont have the stuff Just got a junk yard...Ect
https://www.instructables.com/id/Solar-Thermal-Water-Heater-For-Less-Than-Five-Doll/?ALLSTEPS
If we can get a Few Pics i could help Sugest areas that would be Good...
If you just add a few "addons" to the above link then bam this will help...
add it with the Adtic idea and you boost it...you can always ASK FOR HELP!
12 years ago
I suppose you could raise the temperature by painting the inside of the pool and surrounding deck a matte black.
There is also this Instructable, whose creator might be able to help you with the necessary plumbing skills: Turn excess attic heat into hot water. Circulating water through your attic could not only keep the pool warm, but substantially reduce your air conditioning bills later in the year.
Answer 12 years ago
Thank you for the suggestion. I managed to flood the house once with a dishwasher installation. My insurance company are not impressed with my plumbing skills.
Answer 12 years ago
Aesthetically, very unappealing! I would also have a very hot area in the late summer unless I then whitewashed everything.
12 years ago
How about a set of rails on either side of the pool that will guide the blanket on and off without tipping any collected dirt into the water? Picture the way a shower curtain is attached to the rod.
Answer 12 years ago
Picture a pool 16 feet wide by 32 feet long. Now picture a lady of 60+ who doesn't have a pool boy!
12 years ago
Does your pool have a heater at all, aside from the solar blanket?
Answer 12 years ago
No heater. Not usually needed this far south
12 years ago
tell your neighbor to cut the trees
Answer 12 years ago
Better yet Diydiva, you cut the trees.
Answer 12 years ago
that would be be mean
Answer 12 years ago
In the interests of being neighborly that's not doable. Besides they like the shade!
12 years ago
use the instructables here to build a solar collector, plumb it into the pool filter pump, and ('viola'!, Eureka!, TaDa!, etc.) there you have it.
Answer 12 years ago
I need something rather more passive. My skills are limited and plumbing is not one of them. Thank you for your suggestion
