How can I identify the values of recycled mylar and ceramic capcitors using the codes on the side?
I have desoldered a couple of old radios etc. and am trying to identify all the components I have harvested.
Amongst them I have some green mylar caps. One such cap has the markings: 2A473J
I did a bit of research and found out that usually the first two numbers is the significant figures and the third is the number of zeros. Assuming its not counting the 2A, I'm guessing this cap is 47000pF or .047μF. and I found out that the J is +/-5% tolerance?
Firstly, is everything I have worked out/ assumed true and if so and the cap is .047μF, what does the 2A mean?
Others say 2A73J, 2A103J, 2A332J, 2A222J, 2A102J
Ceramic ones say 4, 22, 30, 33, 102, 103, 104, 203, 221, 222, 331, 332, 333, 473, 682, 683
And I also have 4 of another type of cap that I don't know the name of- they are shown in the 3rd picture.
the two smaller ones say 474 on, one say 8.0M and the other:16.93M
Thanks in advance
Best Answer 8 years ago
When you've got three consecutive digits on a capacitor like that, usually the first two are a decimal number between 0 and 99, and the last digit is a multiplier and a power of 10, and the units for this number are in picofarads.
For example: if you've got a capacitor that has 104 printed on the side, then this means 10 multiplied by 10 to the 4th picofarads
= 10*10^4*(10^-12 F)
= 10^-7 F = 0.1 *10^-6 F = 0.1 microfarads
As another example, 222 means 22*10^2 picofarads = 2.2*10^-9F
= 2.2 nanofarads
Answer 8 years ago
what do you think the '2A' means then?
and the third photo-they say 8.0M and 16.93M?
Answer 4 years ago
http://www.sentex.ca/~mec1995/gadgets/caps/caps.html
Answer 8 years ago
I don't know what the 2A means, when printed on capacitors. I also don't know what a single A, or a J, or a K, means either.
The ones with a M suffix might be ceramic resonators,
http://en.wikipedia.org/wiki/Ceramic_resonator
in which case I think the M stands for "megahertz".
Answer 8 years ago
Yeah i've looked on various sites which tell you how to identify the values but none mention prefixes like 2A.
Nevermind- i'll just pretend it isn't there ;)
Answer 8 years ago
If you find a capacitor with just two digits on it, eg. 10, or 22, or 30. Usually that is just a value in pF, without any multiplier; i.e 10 picofarads, or 22 picofarads, or 30 picofarads, respectively.
4 years ago
8 years ago
Usually/often/ if you're lucky, voltage rating. Capacitor markings are one of electronics' most arcane subjects - second only to SOT23 component marking, in surface mount tech.....
Answer 8 years ago
So you think the 2A might be 2 volts?
Also I read that J is the tolerance??
Answer 8 years ago
No, its some code or other. J could well be tolerance.
Answer 8 years ago
Erm... yeah. J and K are tolerance ratings, 5% and 10%, respectively. At least that's what this place,
http://wiki.xtronics.com/index.php/Capacitor_Codes
says, and I found that place just now, via Google(r).
8 years ago
These caps are at a minimum 50VDC.
I have seen some bypass disc caps rated as low as 12.5VDC
for 5V system ICs.
A
