316Views13Replies
Author Options:
How can I make a countdown timer that runs for 3 years? Answered
I want to have a countdown runner that counts down the seconds (94,608,000). Ideally it only displays the seconds and has no other function. Ideally it does not have to be connected to an external power source but connected with some kind of battery that does not have to be exchanged for 3 years.
Any ideas how to do this? Arduino?
Very new to this community and grateful for any advice!
steveastrouk
steveastrouk
3 years ago
What do you intend to display the count on ?
I think you could do this with a very low power processor and two 8 digit LCD displays. The Arduino is probably good enough, but you will need to be able to do some cute programming to keep the processor is sleep or standby for 99.999999% of its life.
There is a very good code example called, IIRC, Nightingale, where the processor does just that.
anna100
anna100
Answer 3 years ago
For now I was planning on a LCD 16x2 I2C. But I am open to new suggestions!
Couldn't find the code - do you have it handy or should I try again?
steveastrouk
steveastrouk
Answer 3 years ago
That kind of display takes too much power for what you are trying to do. I'm thinking of a display like eInk
Try this link
http://interface.khm.de/index.php/lab/interfaces-a...
Minimum power occurs at minimum voltage and minimum clock frequency. If all you need is an update once a second, you don't need any computing power, and a simple 32768 Hz crystal to drive the processor, making it its own RTC
anna100
anna100
Answer 2 years ago
That sounds very promising! Any chance you have time to go into detail about how exactly I would do that?
steveastrouk
steveastrouk
Answer 2 years ago
Its pretty complex. I'm not sure how you'd handle it in the Arduino eco-system. This article is very informative.
http://www.davidpilling.net/wiki/index.php/Arduino...
For a display, I was thinking of this:
https://www.crystalfontz.com/product/cfap128296c00...
This display draws 10mA ONLY during the update of the data on it, which you could do in a millisecond or so, so the average consumption is roughly 300uWh
If you can afford to update once a minute, instead of once per second, you will reduce the power consumption by a factor of 60, essentially, so 5uWh.
I am pretty sure, one 3.7V Lithium battery will suffice.
iceng
iceng
2 years ago
Simple Citizen watch has hung on my wrist over 12 years using only ambient light for power from the photovoltaic face...
You could buy a watch.. Regrettably it does not record years or months, but it may not be the only model..
Yonatan24
Yonatan24
3 years ago
Don't use a Ni-mh battery.
How about a big battery and a big super capacitor, so it won't reset once you have to replace the battery?
anna100
anna100
Answer 3 years ago
Thanks for the input! Doing my research now on how that could work.
iceng
iceng
3 years ago
A Chinese black blob uP commercial product dependent on CR lithium could not even do a full 2 years.. Opened and replaced the CR2032 battery just for you..
Click the pic to see a whole image..
anna100
anna100
Answer 3 years ago
Thank you!! What is the "countdown to" product that you have on the pictures? Any chance it can be connected to a more powerful battery? Or combine with a super capacitor (see comment above)?
anna100
anna100
Answer 3 years ago
yes that also was my first google search :)
skill set is minimal. basic coding skills. that's why I was hoping to get some inputs from the community?
rickharris
rickharris
3 years ago
Accuratly?
Harder than you think.
For accuracy your going to need a real time clock and a micro processor to read it and display the result.
This will require programming - are your skills up to that - If not start with something simple and work up or copy someone else.
You can do it on your PC
https://www.timeanddate.com/countdown/create
I did this over 2 years when counting to my retirement. The display is on th desktop all the time the PC is on and uses the system clock to calculate.
anna100
anna100
Answer 3 years ago
I'd really want it to be physical (I want to give it as a present to a colleague). Do you have any advice or similar projects I can use as references to make it happen?
