4574Views5Replies
How can I make a spark gap powered by a 9 volt battery?
I had an idea for a project where I will (literally) Set Fire To The Rain. So I need a spark gap. Anyone know how to do this? I think it would be easy to charge, then discharge a flash capacitor. If that's a good plan, where can I find a schematic for a charging circuit?
9 years ago
Alright thanks. What should I look for in a transformer to know if it's the right one?
Answer 9 years ago
Ask a radio shack for a small 12 VAC transformer,
I assume you live in a part of the world that has 220 VAC.
9 years ago
Here is a good spark generator for you.. . A
Answer 9 years ago
Can you explain how this works? What's with the big line of diodes and capacitors?
Answer 9 years ago
- When the coil top side is positive current flows through D1 charging C9.
- When the same point goes negative current is pulled through C9 through D2 charging C3.
- When positive again current flows through C3 through D3 charging C6 and C9..
- When negative again current is pulled through C9 through C6 through D4 charging C4 and C3.
- When positive again current flows through C3 through C4 through D5 charging C7, C6 and C9..
- So on as the transformer polarity alternates the capacitors each build up a couple of hundred volt charge by successive bouts of sequential charging..
The voltage of series capacitors C9-C6-C7-C8 adds up to +2000 VDCat the spark terminal with respect to ground.
A
