1631Views2Replies
Author Options:
How can I make alcohol (for fuel) from celulose (wood, paper) without buying expensive enzymes? Answered
I am fully versed and practiced in column distilation.
Tags:fuel
lemonie
lemonie
10 years ago
Cellulose is particularly tough stuff to break up, that's why using enzymes is one favoured approach. Other than that you need some fairly aggressive chemistry. If you can break cellulose into sugars it can be fermented, then distilled. But you'd want a sophisticated fractional-still to get fuel-grade ethanol out. Not easy L
rickharris
rickharris
10 years ago
Cellulose is very difficult to ferment but the usual methods of adding water to shredded cellulose and keeping warm should produce alcohol that you can then distill off. It may be a slow process.
HOWEVER at l;east in the UK this would be illegal so check you local laws.
I expect you have looked at this http://en.wikipedia.org/wiki/Cellulosic_ethanol
You may expect about 18 gals per ton if lucky.
