1591Views5Replies
Author Options:
How can I make an adjustable rev limiter for a MSD CD ignition? Answered
I have a MSD HVC cd box and coil. The MSD box uses pills to cut off the ignition if I exceed X amount of RPM's. To change it, I have to pop the hood and change pills. I think the pills are resistors. How can I make this where I can set the rev limiter from inside the car like I do the shift light? Thanks, Scott
lemonie
Best Answer 10 years ago
I believe they're resistors, you could wire a potentiometer to the box, probably in series with a fixed-value resistor. Get a multimeter to them and see what it says? L
htmlinc
10 years ago
I just wanted to say thanks to all, I found a website with details. I will try and build it and make an ible. Thanks again!
joealmontehtmlinc
Answer 9 years ago
Would you please give us the link to the website that has the info.
NachoMahma
10 years ago
. The pills are probably resistors, but may be capacitors. You should be able to find out using Google or a VOM. . If they are resistors, remote mounting (see thermoelectric's comment) may add enough resistance to affect the setting. Not sure about caps, but I'm guessing the effect would be worse. Neither should be insurmountable.
thermoelectric
10 years ago
So you want to be able to change the limit from inside the car? Well, You could connect one pin of all of those "pills" together and the other pins of the pills to a switch so you can select between the pills using a switch...
