268Views18Replies
Author Options:
How can I make skin mounted electrodes to use in electrooculograpy? Answered
Electrooculography is a technique where skin mounted electrodes are placed near the eyes to track eye movement. You can look here - http://community.curuxa.org/en/Electrooculograph - for a general idea. Is it possible to make electrodes for this purpose at home?
frollard
frollard
9 years ago
a bandaid, a thumb tack, and a wire would do it...just need the conductive jelly used on the real ones.
Kiteman
Kiteman
Answer 9 years ago
And be careful which way round you mount the tacks...
frollard
frollard
Answer 9 years ago
+3
...one for the suggestion, and 1 more for each of the eyes.
steveastrouk
steveastrouk
Answer 9 years ago
Better to be tackless than tackful here I feel.
frollard
frollard
Answer 9 years ago
see, now that was just tacky.
WWC
WWC
Answer 9 years ago
Now your getting to the point.
frollard
frollard
Answer 9 years ago
these have been bad, but you can't pin that last one on me.
WWC
WWC
Answer 9 years ago
This is starting to pinwheel out of control.
frollard
frollard
Answer 9 years ago
don't worry, I have a plan of at-tack.
WWC
WWC
Answer 9 years ago
That went out the pindow
frollard
frollard
Answer 9 years ago
stick it to the man?
WWC
WWC
Answer 9 years ago
Pin head!
frollard
frollard
Answer 9 years ago
Please get to the point.
WWC
WWC
Answer 9 years ago
Use a tack-switch
Kiteman
Kiteman
Answer 9 years ago
I think that's the most bad puns I've had pointed at my inbox for quite some time...
WWC
WWC
Answer 9 years ago
Point well taken.
iceng
iceng
9 years ago
And you only need a set of millivolt amplifiers to aim your device.
A
rickharris
rickharris
9 years ago
I have a TENS machine that used 2 types of pad.
1. is a conductive rubber - black so lots of carbon.
2. the other is a copper mesh - This has a stick backing like a plaster.
I would look at soldering a wire to the PIN of a brass drawing pin stuck through a sticking plaster st that you can stick the domed head of the drawing pin onto the face. (NOT the pointy bit!!)
To improve the conductivity you can use a water based conductive jell - I understand this is exactly the same as KY jelly only more expensive.
