357Views34Replies
Author Options:
How can I make the firing pin on the ZKAR not break? Answered
The ZKAR v2 has a darn little habit of breaking my firing pins.  Every 100 shots or so, the part that holds the rubberbands breaks off, and I eventually find out that the gray connectors on the firing pin have split down the middle.  It has already broken one of my balljoints, and it still breaks even though I use duct tape.
What should I do?
Tags:PinZKAR
razzlekunai
razzlekunai
Best Answer 11 years ago
Etape that damn pin up
Millawi Legend
Millawi Legend
11 years ago
Get a Leo-Plurodon to fart on it. Its "fart gas" is so thick and gooey that it will solidify around the pin creating a quantum time vortex making an impenetrable layer.
Fred the Penguin
Fred the Penguin
11 years ago
how to make unbelievably strong pin
black rod + ball joint
superglue together
drill hole in both and insert a nail
more superglue
tape with electrical tape (as tight as you can)
slip piece of surgical tubing over top
wrap band around front to renforce and supress impact
if that doesn't work I don't know what will
(short of lathing and grinding a pin out of steel)
DJ Radio
DJ Radio
Answer 11 years ago
I used a ball joint at first, but it broke.  And I want to be able to take the pin apart.
Fred the Penguin
Fred the Penguin
Answer 11 years ago
ok so no glue then, If you want the best pin ever just see if you can use metal ie lathe grind and weld one together
KnexFreek
KnexFreek
Answer 11 years ago
 ive got a steel ram... ill show u on skype if you want :)
Bartboy
Bartboy
Answer 11 years ago
Idea:
Take a k'nex rod (gray or black), with a connector on the back to place your bands (A weak firing pin). Put it in a CNC cutting machine, and use steel. There your go: A perfect firing pin made out of steel!
lemonie
lemonie
11 years ago
My best answer would be to use something other than K'NEX for these bits, but I guess that might be a crime of sorts?
I've only posted an answer because I don't think many K'NEX-ers look around here, and if they did you'd have one - Forum topic?
L
DJ Radio
DJ Radio
Answer 11 years ago
I don't care if it is, any suggestions on what to use?
lemonie
lemonie
Answer 11 years ago
I'm not exactly sure of the stresses on these bits, but I'm thinking of wood or hacksaw-ed 6" nails.
L
DJ Radio
DJ Radio
Answer 11 years ago
The stress is 2 bands, and I just want to know how to make the pin last permanently.
lemonie
lemonie
Answer 11 years ago
Could you see it in wood or steel?
L
DJ Radio
DJ Radio
Answer 11 years ago
Not really.  Is there a super strong tape that you know of?  Stronger than duct tape?
lemonie
lemonie
Answer 11 years ago
You can get Sellotape-type-tape with glass-fibres in it, but that wouldn't really suit a small piece - you get the effect on half-inch plus widths. As I'm not too sure what you're dealing with, I'll take a stab at suggesting epoxy-glue and fabric. But if this needs to be flexible I'm out of ideas.
L
DJ Radio
DJ Radio
Answer 11 years ago
I'll link you to the firing pin: http://i386.photobucket.com/albums/oo306/ZaKnex/DSC01481.jpg
The pin I want to tape up is consisting of an orange connector, then 2 gray connectors sticking up.
KnexFreek
KnexFreek
Answer 11 years ago
 the link doesnt work!!!!!!
DJ Radio
DJ Radio
Answer 11 years ago
Copy and paste it.
lemonie
lemonie
11 years ago
Right it'd the back end bit.
I would wrap in thin cloth, coat in epoxy glue, then apply more cloth & epoxy glue in place of the tape you're using.
L
KnexFreek
KnexFreek
Answer 11 years ago
...... glue + knex = ruined knex! LOL!
The answer is use Etape. *electrical tape*
it works amazingly.
And whaaddya know, the selected answer was ... ETAPE! LOL
DJ Radio
DJ Radio
Answer 11 years ago
I want to be able to take the pin apart when I am done and want to build something else.
lemonie
lemonie
Answer 11 years ago
-which you can't do if the bits are broken. If you're sacrificing parts, there's not many (more) lost. And you could probably hack the stuff off afterwards.
L
DJ Radio
DJ Radio
Answer 11 years ago
First of all, I already took the gun apart a few weeks ago.  Second, I made it EXACTLY as in the instructions.
DJ Radio
DJ Radio
Answer 11 years ago
I just selected the first answer that had "Etape".
Killer~SafeCracker
Killer~SafeCracker
Answer 11 years ago
I know. I just built the ZKAR and let you know what I did.
travw
travw
11 years ago
I have no clue. I can dry-fire for hours with 5 #64's. So..... Idunno. Use hot glue, and stretched out Etape. All I have is electrical tape and mine's fine.
knexfan9182
knexfan9182
11 years ago
Use electrical tape it has more elasticity, and will bind the pin better but make sure its stretched out really good.
Jesus.
Jesus.
11 years ago
how many bands are you using??
DJ Radio
DJ Radio
Answer 11 years ago
2 bands, not #64's.
NYPA
NYPA
11 years ago
Either use less bands, or use a rubber band to supress it.
DJ Radio
DJ Radio
Answer 11 years ago
I only have 2 bands on, and I do have a rubberband suppressor on the pin guide.
NYPA
NYPA
Answer 11 years ago
Use a yellow connector instead of a second gray. It takes all of the force.
mettaurlover
mettaurlover
11 years ago
use metal repair tape then duct tape it-the repair tape will hold the pieces together like cement, and the duct tape will make it not look like you coated the end of the pin in aluminum foil. yes, the tape really looks like foil. it's pretty much just a strip of the stuff, with a plastic back that's insanely sticky and nearly indestructible compared to duct tape's stickiness. NEVER put it on metal that you want to get it off of. not gonna happen.
