969Views23Replies
Author Options:
How can I modify a basic mains timer switch (non-digital) to work with DC? Answered
DC timers are extremely costly compared to their AC counterparts and can be very complex.
I'd essentially like to modify one of these guys to work with DC, plugged in a circuit, instead of the wall outlet.
Here's an example of the timer switch stuff I'm referring to: http://www.dbjholdings.com/images/300x300/5022822160514-3-1.jpg
So... how can I do it? I'd like ot to accept a wide range of input voltage (12v to 32 but 20 to 32 would also work if it makes it easier)
Thank you guys!
steveastrouk
steveastrouk
6 years ago
Those have motors in them which only run on AC. The cheap AC DIGITAL timers are more hackable.
atkers
atkers
Answer 6 years ago
This is as cheap as it gets? It's like few bucks only :)
steveastrouk
steveastrouk
Answer 6 years ago
I've picked up digital ones for well under 10 bucks. And they can be modified. These can't
atkers
atkers
Answer 6 years ago
Well, I don't want to pay over $5 each. There are DC timers for $5 anyway..
iceng
iceng
Answer 6 years ago
Are they to be 24 HR repeating timers ?
atkers
atkers
Answer 6 years ago
I need a clock with pins on them so it can be easily changeable. Isn't there a way to hack these timers? I can replace motors if necessary..
steveastrouk
steveastrouk
Answer 6 years ago
The motors are AC types, they are called synchronous motors, because they spin at exactly and always a fixed multiple of mains frequency, and then its geared down so that the dial turns once every 24 hours.
atkers
atkers
Answer 6 years ago
Ok. What if I find one of these analog timers that work on a battery but without digital screens and buttons and all the stuff. Would it be relatively easy to get it turn on/off a DC circuit?
atkers
atkers
Answer 6 years ago
Sure! http://www.ebay.co.uk/itm/NEW-24-HOUR-PROGRAMMABLE-TIMER-FOR-UK-MAINS-WALL-HOME-SOCKET-PLUG-IN-SWITCH-/360923541348 this one says it needs a battery to run.
steveastrouk
steveastrouk
Answer 6 years ago
Still looks like a mechanical one to me.
atkers
atkers
Answer 6 years ago
steveastrouk well, I'll take your word for it. thanks for checking it out for me.
atkers
atkers
Answer 6 years ago
steveastrouk
steveastrouk
Answer 6 years ago
$5 is "extremely costly" ?????
atkers
atkers
Answer 6 years ago
Yes. I'm trying to hack things here :)
iceng
iceng
6 years ago
After you have modified a timer what will it be used to switch.
AC, DC, voltage, current ???
atkers
atkers
Answer 6 years ago
It will turn on / off a DC circuit. I really need a DC timer :(
iceng
iceng
Answer 6 years ago
What AMOUNT of DCurrent @ 12-32 V DC ????????????????????/
atkers
atkers
Answer 6 years ago
It needs to be flexible if possible. I need varying amounts. (1x 24v, 1x,27v, 1x31.5v)
atkers
atkers
Answer 6 years ago
Current passing through will be 0.9a, 1.05a, 2a.
iceng
iceng
6 years ago
You don't have any idea what current ?
Here you go, under $5.43 of components...
steveastrouk
steveastrouk
Answer 6 years ago
Neat circuit. DIdn't there used to be 555's with the counter built on them ?
iceng
iceng
Answer 6 years ago
Recall something like that, Ill check my stock next time Im in back to the lab.
steveastrouk
steveastrouk
Answer 6 years ago
I can't remember the number.
