122Views9Replies
Author Options:
How can I "petrify" a T shirt? Answered
I had this idea for a gift for a friend. It's kind of an inside joke, and I know he'll really like it.
I would like to take a T shirt, and somehow "petrify" it. My idea is to make some sort of form out of wood, or foam, or something. I would put the shirt on the form, and epoxy it. I thought I might wrap the form in plastic wrap, so that the shirt sticks to the wrap, and I can lift it off.
Is this possible, and if so is there a better way to do it?
lemonie
lemonie
Best Answer 10 years ago
The resin used for glass-fibre would do it, but for real & true petrification hang it under a highly-mineralised source of water.
Do as you think above, but get some resin for glass-fibre, and do it in a well-ventilated area.
L
noahh
noahh
Answer 10 years ago
Epoxy won't work?
lemonie
lemonie
Answer 10 years ago
 Yes you can do it with epoxy, but you'll probably find it easier to get the quantity you need in the glass-fibre resin.
L
noahh
noahh
Answer 10 years ago
I'm a bit stuck on this one. I'm sure you're right, but in the past when I have worked with fiberglass, I have had an awful reaction, and it makes me dreadfully itchy.
lemonie
lemonie
Answer 10 years ago
It's a gift for a friend - keep yourself covered.  Or hang it under a highly-mineralised spring for a year or two...
L
RavingMadStudios
RavingMadStudios
Answer 10 years ago
Fiberglass resin  is pretty much the same thing as epoxy, just cheaper and easier to work with in larger quantities.
frollard
frollard
Answer 10 years ago
...and epoxies tend to have 50/50 mixes while resins use 99.5%:.5% ratios of resin to catalyst...probably the same reaction as you say though.
RavingMadStudios
RavingMadStudios
Answer 10 years ago
...and fiberglass resin tends to be more brittle than epoxy when it's not reinforced with fibers, plus it turns that hideous green color when it cures. Still, it's close enough for rock & roll (and the hideous green color can be avoided by using casting resin, if that's an issue).
Re-design
Re-design
10 years ago
If you use epoxy thing it some with rubbing alcohol.
