435658Views19Replies
Author Options:
How can I quickly soundproof a room, or at least lower the decibel level experienced outside of the room? Answered
I need to soundproof a room for cheap -- under $50 dollars perferably. Are there any easy ways to sound proof the room? I've heard that the old style of egg cartons can be used to soundproof, is it possible to use those?
LeighB30
LeighB30
4 years ago
Well, for under $50 you're gonna find it difficult. Actual soundproofing is totally different from sticking some egg cartons on the wall. That's ( a very basic ) form of sound treatment. Soundproofing would involve reconstructing your room entirely to create airtight surfaces that eliminate sound entering along with the air. For 50 bucks and under your only option is sound treatment and for that amount of money, a set of the thickest possible curtains will have the most effect. Windows are the biggest weak point when it comes to unwanted sound. The second greatest weak point is doors. Cover the windows first. I put up two sets of curtains when I lived in a very noisy neighborhood. It dropped the decibel level about 2 db.
AuralArch
AuralArch
6 years ago
I know this is WAY too late for the OP- but for anyone whose search may lead them here... There's a CRUCIAL element to effective soundproofing that wasn't mentioned at all.
And that is: making the room/space AIRTIGHT. Sound travels best through the air- even small holes, cracks & crevasses. It is astonishing how much you can reduce the level of sound coming from a room by sealing it up around the door(s), window(s) & etc. Use weather stripping foam, caulk- whatever you have or can get. If it were feasible to create a second airtight insulating buffer/layer 'deadzone' that would probably almost kill all sound transfer. Except for the bass...
Blankets, mats, egg cartons, pillows & stuff like that will help with higher & mid-range frequencies. But bass- especially loud bass- is the hardest to deal with. Basically it requires more mass & density to absorb or block- a LOT more. And that's where things start to get expensive.
MatejD6
MatejD6
Answer 4 years ago
Are sure that "Sound travels best through the air" ?
MatthewL147
MatthewL147
Answer 4 years ago
Yes sound travels through air. Same reason why there is no sound in space, there is no air to carry it.
MatejD6
MatejD6
Answer 4 years ago
"best" ? (solid materials)
kastrosama
kastrosama
9 years ago
a good thing to look out for is any festivals that attract a young crowd, most of them are littered with tents, sleeping bags and sleeping mats at the end, collect loads of sleeping mats and use them to layer your walls.
RW19
RW19
Answer 4 years ago
Oh, I do like the way you think! I am perpetually scavenging at the bottom of the food chain (but at least I'm still on it : ) Working on anti-helicopter traffic soundproofing - probably make a door plug with the found panels of tabletop mats (resembles homosote? but finished with decorative (preferably gassed out) vinyl on one side and velvety covering on the other side) then thick yoga mats fixed to that. The windows will be found plexiglass with attached magnet strips to stick on window frame steel brackets.
GeneT2
GeneT2
5 years ago
My friend wants to get an old Single wide trailer and make it. Into his. Personal gun range in back of his house
He has 500 bucks to make it sound proof. Any Ideas ??
aginnsz
aginnsz
7 years ago
Could you please be more specific about your situation: Are you getting noise complaints? Where do they come from (apt above, apt below or adjacent apt(s)? What is the source of the sound (stereo, footsteps, snoring....)? Etc...
Without more information, it is impossible to give you any advice. For instance, if you're getting noise complaints from the apt right above you, none of the answers below will work, and you will ruin your walls for nothing.
parallux
parallux
7 years ago
The egg cartons and other sound absorption techniques work, but that won't stop the sound from getting in in the first place. I've been working in the acoustic industry for a number of years, and we only suggest sound absorption products for people that want to improve speech intelligibility or resonance within the residence. To keep noise out in the first place, you need a dense material that will add mass between the noise source and yourself. I suggest a soundproof curtain or door if the noise is coming through those openings (which it often does). Residential Acoustics has these @ http://residential-acoustics.com/product/acousticurtain/ and there are a number of other sites that offer similar products (Soundproof cow, acoustical solutions, etc.)
Hippykidz
Hippykidz
10 years ago
Egg crates are the way togo. Try going to your local fast food joint. One that serves breakfast they go through tons of the things and I am sure would be willing to hold for you for regular pick up.
ronchi84
ronchi84
10 years ago
If it is a small room, got to wal-mart in the camping section and get rolls of camp mat.  it costs about $3 a roll and comes in about a 7' x 3' piece.  it will be close to $50 for a small room.  just ran some figures, it will cost about $20 a wall for a 14' x 14' room with 8' cielling  so a little less than $80 minus mounting supplies
acidbass
acidbass
11 years ago
guardian fox is right but what we do in my church since we go to a very small one we put carpet all over the walls
professor2005
professor2005
11 years ago
Egg cartons would help but you would need a lot of them. Acoustic foam is pricey. Carpeting and foam padding on the wall would probably give you the most bang for the buck. Try thrift stores or Craigslist . Don't forget the door!!! Other than that. Styrofoam panels cardboard (refrigerator boxes flattened on the walls) Moving blankets
A_of_s_t
A_of_s_t
Answer 11 years ago
For cardboard, would I just tack it onto the existing wall? Or would I hang it from the ceiling?
cerberustugowar
cerberustugowar
11 years ago
I'm on the blanket band wagon. I think that would be the quickest thing and you likely have them on hand. If it's temporary, borrow friends blankets
orksecurity
orksecurity
11 years ago
Just be careful not to create a fire hazard. Remember that the Station fire (see Wikipedia if you don't remember it) was largely a matter of inappropriate soundproofing that caught too easily and burned too rapidly.
Burf
Burf
11 years ago
If you're seeking a temporary solution, hanging blankets or quilts on the walls will help. If you are taking tuba lessons, you'll need to go with something more permanent. Remember soft things, fabrics, expanded polyurethane foam and other insulating materials will work. Bringing it in for under $50, that's gonna require some recycling skills.
