73Views4Replies
How can I replicate this?
Particularly the display that says volts , I have no problem pushing the data to the numerical display but I have no idea how to go about making the light up display that says Volts.
http://www.tomsdigitalelectronics.com/yahoo_site_admin/assets/images/gt_aux_in_green.67132051_std.jpg
6 years ago
LEDs and a mask with the word cut out. Add some sort of semitransparent diffuser material in the cut out to help light it evenly.
Answer 6 years ago
Here's a quick model.
Answer 6 years ago
Never thought of using a mask; I'd normally print it out on paper and use a scroll saw to cut it out. Your idea sounds much Simpler !
A quick tip for the mask though, Try printing you design on an overhead transparency; just hit your local print shop. Leave the "Volt" transparent and the rest of the mask black ,@ maximum Toner thickness. Use spray glue on the toner side of the transparency, then add the coloring/diffuser layer as Bwrussell Sugested.
Good luck; Hope to see an Instructable when your done :D
Answer 6 years ago
Thanks! Really appreciate it
