65Views1Replies
How can I slow down an 230v electrical fan motor???
Hi.
I have this fan but the lowest speed is too LOUD!!!
Would it be possible to solder on a resistor or something like that?
The label says: Induction motor
Class E
230v 50Hz 40w
model DT30B
There is also a speed controller 0,1,2,3.
Let me know if I should capture the fan/label.
I am very grateful for all responses.
Thanks.
2 years ago
I expect the cheapest way to fix this is to just buy a smaller, more quiet, fan.
Induction motors, typically, are not easy to drive over a wide range of speeds, not without adding hardware, like a variable frequency driver, that would be more expensive than the motor itself.
In contrast, other kinds of fans, like the fans they put in desktop computers,
https://en.wikipedia.org/wiki/Computer_fan
https://en.wikipedia.org/wiki/Computer_fan_control
These are cheap, ubiquitous, and easy to drive over a wide range of speeds. The only disadvantage of these little computer fans, is that they are small.
I mean if you really do need something like 40 watts of air moving power, it would be huge number of little computer fans, since the typical power consumption for one of these little fans, like the square-shaped, 80 mm, or 120 mm sized ones, is around 1 or 2 watts each.
But they are easy to drive, over a wide range of speed. A typical computer fan is powered by a DC voltage source, in the range from 0 to 12 VDC, and the speed at which it turns is roughly proportional to the voltage, or the time-averaged voltage if using PWM.
