854Views6Replies
Author Options:
How can I switch on a well water pump? Answered
I have this well water pump that is connected to a wall plug which gets switched ON and OFF by a float switch in the reservoir. What I want to do is to switch ON the pump from down where the pump is, when the float switch in the OFF position without going up to the reservoir ,
steveastrouk
steveastrouk
11 years ago
Then you want to do what Sean and I said. Add a switch across the float switch.
lonzu
lonzu
11 years ago
Thanks for your prompt replies. excuse my ignorance but please let me refresh my question. I want the float switch to keep doing it`s work by switching on/off the pump. I want to switch on the pump for when I need water in the yard where the pump is, so that water flows from a water tap that is connected with a tee just on top of the pump when the float switch is in the OFF position, Thanks again
seandogue
seandogue
11 years ago
The float should be a remote sense connection, ie, a low voltage trip for a relay, which does the actual "work" of switching on/off the pump motor. Simply bypass the sensor with a manual switch.
seandogue
seandogue
Answer 11 years ago
K1 relay LS1 float *Assumed 24V low voltage remote (pretty standard) Also assumed single phase or DC sump.
steveastrouk
steveastrouk
11 years ago
This circuit will keep the pump on, and ignore the float switch. I suspect though that your float switch might drive a box that goes click near the pump ??? That's a relay, to stop the float switch having to work hard with the pump current. If there is a relay, I'll draw another circuit.
lemonie
lemonie
11 years ago
Do you want a long-range remote switching, or can you work with long wires? L
