103Views5Replies
Author Options:
How can I transport water up into a tank that is 10m vertically above? Answered
Hi Instructablers,
As what mentioned in the topic, I am thinking of transporting water from my leaking pipe back into my tank which is roughly 10m above?
Lets not talk about replacing the leaking pipe.
Help help help!
Toga_Dan
Toga_Dan
5 years ago
Possible that the leak is not a "defective" pipe, but just something loose, or a bit o dirt in the wrong spot.
kelvintoys
kelvintoys
Reply 5 years ago
Hi, nope. It is actually supposed to be like that. Just assume the leaking is unavoidable (It is desired actually), is it possible to collect them with a container and use a ram pump to pump the water up to 4m height tank?
Toga_Dan
Toga_Dan
Reply 5 years ago
yes, ram pump can work, if you have a running stream With enough flow.
May i ask the purpose of the leak?
Toga_Dan
Toga_Dan
5 years ago
is the pipe leaking because it rusted out? Or because someone forgot to use teflon tape for a threaded fitting? Or a solder joint that was inadequately fluxed? Or?
Downunder35m
Downunder35m
5 years ago
You don't want to fix the problem so your options are:
Buckets, bottles sponges or simply a pump.
But I gues I don't really want why...
