809Views10Replies
Author Options:
How can I use a 50w bulb in a 150w socket? Answered
I am converting alp720 lamp into a regular lamp for easy replacement. I can get it all to work, save two problems, 1 I have to hold in the reset button because the lamp is not tied to the circuitry and 2 I have to have an extra cord to run the light. Can I short the system somehow and run the wiring from the on off switch itself?
lemonie
lemonie
11 years ago
I don't really know what you're talking about here, but "50W in 150W socket" is a "yes of course" type of thing - no resistor required.
L
orksecurity
orksecurity
Answer 11 years ago
Assuming they're the same kind of socket, and at the same voltage, of course. And there may be other mechanical/heat issues depending on what kind of bulb you're talking about.
But if you're talking about standard edison-base bulbs, a 150W fixture will accept any bulb up to 150W.
lemonie
lemonie
Answer 11 years ago
It's all rather vague, but reminds me of "can I use a 3A power supply to run a 1A device?"
L
orksecurity
orksecurity
Answer 11 years ago
Very much so. (And we probably forgot to say "As long as that isn't a 3A supply regulated for current rather than voltage...")
dk1252
dk1252
11 years ago
This not a recommended "hack". There's a reason it's only rated for 50 watts; that's all the components can handle. If you modify it in any way, you risk a fire. An electrical fire... dangerous, smelly, and destructive.
My advice: go find a 150 watt socket. They're CHEAP.
Re-design
Re-design
Answer 11 years ago
THe bulb is rated 50 watts not the socket.  If the voltage is the same there should be no problem.
Jaims0075
Jaims0075
Answer 11 years ago
Well I have the actual case for the bulb but the bulb is 400 to 500 but even if it was 100 I could not afford it right now. That is why I wanted to used the 50 watt the lumen's is just about the same. so even if I use a 300 ohm resister this is no good?
origamiwolf
origamiwolf
Answer 11 years ago
No, because there's going to be a heck of a lot of heat dissipated in that resistor (assuming it's even rated for that much power), and that would be dangerous.
Re-design
Re-design
11 years ago
You can always use a lower wattage bulb in a light rated for a higher wattage bulb - IF the voltages are the same.
Can you provide a link the the type of light you are using?
origamiwolf
origamiwolf
11 years ago
Perhaps a better way of approaching this would be to find out what the voltage ratings are for the two bulbs?
