981Views10Replies
Author Options:
How can I get a fly back transformer from a ionic air purifier to work? Answered
I took apart a ionic purifier and i haven't cut many wires(I needed the switch.), but i need help using it as a hv supply.
There's four different wires red, black, yellow, and white and i need to know witch ones to connect to get it to work. I'll have pics later.
UPDATE: Now I have pics.
P.S. It worked before I took it apart.
oldmanbeefjerky
oldmanbeefjerky
8 years ago
look at the biggest transistor on the circuit board, it will likely be a mosfet, and / or heatsinked.
it should go directly to some of the pins on the flyback, that would be the internal power IN, or internal primary.
The ground is easy enough to find as it is likely directly connected to the power supply negative.
The flyback HV wire is likely the thickest one comming out of the top.
however, it has an external ferrite, so you can probably wind a new primary on, it just takes like 5-10 windings of any old insulated wire.
If you have the means, run the thing and check the frequency and pwm it runs at, and then just build an oscillator circuit which produces the same output, or just build the circuit the mad scientist recomended. i have, and it works great.
follow the guide on that site , it will work the same
RocketPenguin
RocketPenguin
Answer 8 years ago
Ok, i will look into it. I hope i still have it...
RocketPenguin
RocketPenguin
Answer 9 years ago
were? on the flyback or on the circuit ?
The MadScientist
The MadScientist
Answer 9 years ago
On the flyback.
I will also note you spelt Nicola wrong it is spelt Nikola.
RocketPenguin
RocketPenguin
Answer 9 years ago
i know i know but it was to late to change it.
and i would have no clue if it is on the flyback.
Nelson_Yepez
Nelson_Yepez
9 years ago
well if you had a picture it will be easer to help but as right now if it is a fly back it will not shock you, it will kill you so be careful.
Adam Manick
Adam Manick
9 years ago
it is probably not a playback transformer. Try to hook up the red and bleach wires to pulsating dc and the other wires might be outputs. Search for flyback driver and use that circuit. Be careful. These can shock you.
RocketPenguin
RocketPenguin
Answer 9 years ago
well it has ten pins on the bottom and a big red wire on the top. there are three wires connected to different pins i'm guessing positive, negative, high voltage ground. thats what i think.
