2010Views5Replies
Author Options:
How can I use solar power to run a hexbug nano (little toy with little motor)? New to electronics, over explain ;) Answered
shortdiesel
shortdiesel
Answer 9 years ago
This is what I was looking for. I just need to learn how to free form the components. It shouldn't be too complex, but I am still a beginner.
Thanks to all who replied!
gruffalo child
gruffalo child
9 years ago
Well, in theory you simply find a solar panel that it can feed from (it has 3V, or am I wrong?) and use it simply instead of the batteries. Or for a more sophisticated version you can use the solar panel to charge the batteries. HOWEVER, if I'm thinking of the right toy (a small cockroach style thing with a sort of rubber brush underneath), the bug is quite sensitive even to changes of the brush position after being squashed in a pocket, and adding extra weight will change his pace terribly, if not totally immobilize the poor soul, as solar batteries don't come small (they need a big area, don't they?!).
I would try to stick different weights to the bug, and if it can carry at least 5 grams, then think further.
Good luck, G
gneedel
gneedel
Answer 9 years ago
The nano runs on 1.5 volts, so if you found a small solar panel and soldered it to the leads where the battery waswith enough light you could make the nano move.
Note: If you do this please make sure you remove the battery because they are not rechargeable.
R.A.T.M
R.A.T.M
9 years ago
well thay run on 4.5 so get one of these it should not b to much power than solder the leads to the +(red) and -(black) to the nano battier batteries and uv done it don't have the batteries in the nano wile using
