720Views15Replies
Author Options:
How can I use this router bit? Answered
I recently purchased a big 2 HP router and a 15 bit set from Harbor Freight. The router is going on the finished CNC router, but I also needed it to make a few chamfers on the sides of some of the parts. The router is one speed, and says that it has a "Maximum RPM of 29000". The chamfer bit that came with the set, on the other hand, says that it has a max speed of 18000. What do I do, now?
Burf
Burf
Best Answer 9 years ago
You can buy router speed controllers at many hardware and most woodworking supply stores. But a word of caution, there is no way I would ever consider using those big a$$ bits in a hand held router. One slip and serious damage can occur, to the wood piece or flesh.
Build a small router table and use that instead, its safer and does a better job.
Shagglepuff
Shagglepuff
Answer 9 years ago
I am definitely going to build a router table- the thing sounds like a jet engine. Are there any other ways to slow down the router (without a store-bought speed control)?
Burf
Burf
Answer 9 years ago
harbor Freight sells some cheap ones for around $20. I wouldn't want to take a chance on burning up an expensive router to save 20 bucks.
Shagglepuff
Shagglepuff
Answer 9 years ago
...eh, you're right. I think I'll just return this router and get a trim router with the harbor freight speed control.
tskil5
tskil5
9 years ago
if you want to slow the router down, i've often used (on other projects) an old sewing machine foot control. they work well because a sewing machine is also rather heavy duty and wont burn out.
mpilchfamily
mpilchfamily
9 years ago
You can build your own speed control out of a wall outlet or old power strip and a dimmer switch.
Shagglepuff
Shagglepuff
Answer 9 years ago
From what I've heard, most dimmers will practically explode when used with something as powerful as a router.
mpilchfamily
mpilchfamily
Answer 9 years ago
I've had no problem with a dimmer and a dremal.
Shagglepuff
Shagglepuff
Answer 9 years ago
A dremel 300 draws 1.15 amps. This router of mine draws 11. If only....
rickharris
rickharris
9 years ago
Round the wood by hand - using a plane and glass paper (sandpaper)
frollard
frollard
9 years ago
For those larger bits you need a variable speed router or you risk making some fun metal shrapnel to wreck your day.
Shagglepuff
Shagglepuff
Answer 9 years ago
That's where the problem comes in- for now, that big 2 HP router is all I have. I'll probably buy a speed controller for it in the future, but I need a temporary fix for it right now. Is there any way to slow down the router or make the cut with a different method?
frollard
frollard
Answer 9 years ago
use a smaller bit that can handle the rpm's...and if its cnc - program it to do more passes.
Vyger
Vyger
9 years ago
What you need to know is what its normal running speed is. The max is just that, it's self destruct beyond this point hi speed. But that speed is probably not the speed it usually operates at. That speed is probably much lower.
