If you mean lb/in2 you could convert it to other forms using these formulas psi x 144 = lb/foot2 psi x 0.068045964 = atmospheres psi x 703.06958 = Kg/m2 psi x 6,894.7573 = pascals psi x 5.1714932 = cm of Hg psi x 2.0360207 = in of Hg psi x 0.068947573= bars
I cant thick of any others and if you need to go back words then replace the = with / and the x with = and work from right to left
Best Answer 11 years ago
11 years ago
Is this some kind of pneumatic gun?
You need to run some ballistic tests, how about this one?
https://www.instructables.com/id/how_to_measure_the_FPS_of_an_airsoft_knex_or_oth/
L
11 years ago
F/m) to arrive at velocity (v = vo+at).
