97Views5Replies
Author Options:
How can a I make a circuit to change between 5 led lights in order when a button is pressed Answered
I hope i'm asking this in the right section and please bear with me i'm a real beginner.
I tried to googleit but I don't know the name of what i'm trying to accomplish.
I want to build a circuit that does the following:
I have 1 on off switch, 1 momentory off - on push button and 5 led lights.
When I power the circuit using the switch I want the first led to be on.
When I press the push button I want the second led to turn on and the first to turn off.
And so on.... when the fith led is on and the button is pressed I want the first led to turn on.
I hope that explains it clear enough for you to get what I am after. If anyone can point me in the direction of a guide/tutorial on how to accomplish this it would be a great help.
Thanks
Hussam
Hussam
9 years ago
You can use a microcontroller .. 5 pins as output which will be tied to the leds and two for the switches .. its quite a simple program .. any controller will do the trick although for this use a 12 pin pic or something like that!
freethetech
freethetech
9 years ago
You could do this with a microcontroller if you're into them. I used to work with purely ICs (I suppose I still do), and built hard circuits. But I've since moved to microcontrollers. I loved working with individual IC chips, but I don't have the time for that. I'm a code junkie, anyway xD
joepublic
joepublic
9 years ago
Thanks for your help.
I had a look at that circuit and I think I understand whats going on.
What is the chip called that all the LED's are going into? So I know what to buy...
steveastrouk
steveastrouk
Reply 9 years ago
Its a 4017 Decade counter IC.
Steve
