78Views3Replies
Author Options:
How can i combine these 3 codes?i'm completely new to arduino ? Answered
code 1: Ultrasonic sensor and LCD I2C Display
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h>
#include <NewPing.h>
#define I2C_ADDR 0x3F // <<- Add your address here.
#define Rs_pin 0
#define Rw_pin 1
#define En_pin 2
#define BACKLIGHT_PIN 3
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
#define ECHO_PIN 11 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define TRIGGER_PIN 12 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define MAX_DISTANCE 500 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
void setup()
lcd.begin (16,2); // <<-- our LCD is a 20x4, change for your LCD if needed
// LCD Backlight ON
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.home (); // go home on LCD
lcd.print("Obst. distance");
void loop()
unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
unsigned int cm = sonar.convert_cm(uS); // Convert into centimeters
lcd.setCursor (0,1); // go to start of 2nd line
lcd.print(" Distance:");
lcd.setCursor (0,3); // go to start of 4th line
lcd.print(": ");
lcd.print(cm);
lcd.print(" cm ");
delay(500);
code 2: PIR sensor with buzzer
// Uses a PIR sensor to detect movement, buzzes a buzzer
// more info here: http://blog.makezine.com/projects/pir-sensor-arduino-alarm/
// email me, John Park, at jp@jpixl.net
// based upon:
// PIR sensor tester by Limor Fried of Adafruit
// tone code by michael@thegrebs.com
int ledPin = 13;                // choose the pin for the LED
int inputPin = 2;               // choose the input pin (for PIR sensor)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status
int pinSpeaker = 10;           //Set up a speaker on a PWM pin (digital 9, 10, or 11)
void setup() {
  pinMode(ledPin, OUTPUT);      // declare LED as output
  pinMode(inputPin, INPUT);     // declare sensor as input
  pinMode(pinSpeaker, OUTPUT);
  Serial.begin(9600);
void loop(){
  val = digitalRead(inputPin);  // read input value
  if (val == HIGH) {            // check if the input is HIGH
    digitalWrite(ledPin, HIGH);  // turn LED ON
    playTone(300, 160);
    delay(150);
    if (pirState == LOW) {
      // we have just turned on
      Serial.println("Motion detected!");
      // We only want to print on the output change, not state
      pirState = HIGH;
  } else {
      digitalWrite(ledPin, LOW); // turn LED OFF
      playTone(0, 0);
      delay(300);
      if (pirState == HIGH){
      // we have just turned off
      Serial.println("Motion ended!");
      pirState = LOW;
// duration in mSecs, frequency in hertz
void playTone(long duration, int freq) {
    duration *= 1000;
    int period = (1.0 / freq) * 1000000;
    long elapsed_time = 0;
    while (elapsed_time < duration) {
        digitalWrite(pinSpeaker,HIGH);
        delayMicroseconds(period / 2);
        digitalWrite(pinSpeaker, LOW);
        elapsed_time += (period);
CODE 3: MQ5 LPG gas sensor
int sensor=7;
int gas_value;
void setup()
pinMode(sensor,INPUT);
Serial.begin(9600);
void loop()
gas_value=digitalRead(sensor);
Serial.println(gas_value);
-max-
2 years ago
It is possible to get all the code you want hacked together, but you should learn the reason for each and every line, what it does, why, etc.
Downunder35m
2 years ago
Might be a good idea to start with some simple things first.
After all most people learn how to drive a car before they jump onto a semi trailer....
steveastrouk
2 years ago
You can't. You have to define the function you are trying to achieve first, and then possibly reuse some of the code.
