52Views1Replies
Author Options:
How can i compress a biogas from a compost tank without risk of ignition. Answered
i already have minor semblance of a design but, i always prefer to consult the hivemind before doing something potentially stupid(i'm missing enough fingers). so, big picture is to create basically a sealed septic tank tied into the water lines of a residential house, which would produce methane to be stored year round then used during the cold season. not so much that i could cut off the natural gas line, but enough to reduce the bill.
the design so far is a gas line coming from the septic tank connected to a bladder sitting inside a large tube. once the bladder reaches a nominal capacity, it will trip a sensor near the top of the tube activating a compressor until the bladder retracts to a lower set optical sensor turning off the compressor. somewhere in this mix i have the intent to set up a large air filter filled with that "oxygen eater" stuff they use in food storage applications. as well as several o2 sensors in the main line set up to stop the compressor and activate a solenoid valve to make sure no oxygen ever get to the compressor.
what i dont know, is what kind of compressor i should be using to avoid any type of possible spark. proper placement of the o2 sensors, and if a giant air filter for eating oxygen already exists or is that something im going to have to make the hard way.
Tags:science
Toga_Dan
Toga_Dan
3 years ago
I would think a diaphram compressor might be advised. no metal on metal sliding. it might be advisable to slow it down, too, for less heat. consider, not only spark as ignition, but deiseling. water cooling of the pump and piping may prevent deisel ignition.
