105Views4Replies
How can i fix corrupted CD?
Hello,
Please help…am having an issue with a CD that has very important data in it. And now the CD is corrupted.
How can i get the data from the corrupted CD? It’s really very important!!
Thanks!
Hello,
Thanks!
Best Answer 6 years ago
Hello!
This
problem is also discussed on forum -http://www.filerepairforum.com/forum/other/other-aa/cd-dvd-hd-dvd-blu-ray-etc/709-%E2%80%8Bcorrupted-cd-file-need-to-be-recovered
I hope it will help
6 years ago
Assuming the disk is clean and clear of scratches and cannot be red trying multiple known good drives i'd say the coating on the disk itself is deteriorating. This can happen over time or due to exposure to heat and/or exposure to UV light. In which case you have little hope of recovering the lost data. There are some software packages that will try to do a bit for bit read of the disk to retrieve as much data as possible but it's vary likely the information is beyond repair.
6 years ago
i would breath steam onto the disk (on the shiny side) and wipe it off with you shirt
because when someone touches it may leave residue
6 years ago
Corrupted?
You mean scratched or otherwise unreadable?
If you mean real data curruption due to failure of the organic material holding your data I see little chance.
Scratched CD's you can clean and first order of business would be to create an image file from the CD to work with.
