360Views6Replies
Author Options:
How can i repair my mbr through ubuntu? Answered
A while back i installed Ubuntu so i could familiarize myself with it for a class i was taking. The boot loader only loads twice then the system needs repaired. The boot gets stuck at "verifying DMI pool data" and I have to put in the ubuntu disk and choose rescue a broken system and reload the GRUB boot loader.
Whenever i shut down Windows to boot into Ubuntu Windows updated and now i cannot boot to it without getting stuck in a loop because it must reboot to work.
Is there a way i can get the windows boot loader back or do i need to keep rescuing it?
tragicallyhip
tragicallyhip
Best Answer 9 years ago
Use your MS disc, let it load till you get the recovery console fix with command prompt type "fixmbr"
gantyman
gantyman
Answer 9 years ago
can i do this through windows itself or does it need to be through the recovery console?
tragicallyhip
tragicallyhip
Answer 9 years ago
Only through the recovery console ,you pc will only have minimal funcntions so nothimg will interfear with fixmbr
Vyger
Vyger
9 years ago
Hard drives are now cheap enough that you could, should, use a separate drive for each OS. In the bios screen, you pick which one to boot from and that way they will never mess each other up.
tragicallyhip
tragicallyhip
Answer 9 years ago
A better solution for testing out Ubuntu without a full install would be to use Wubi. The distro will install as a regular X86 application on your PC and when your done remove it as you would any other windows program
gantyman
gantyman
Answer 9 years ago
i do have them on different hard drives.
