149774Views15Replies
How do I attach 2 pieces of metal together without a welder and still be structurally sound?
I want to play around with building a recumbent bike and a rear steer trike type bike but I dont have access to a welder, would gorilla glue or a jbweld like epoxy be strong enough to use?
1 year ago
For me, all my friends, when they do such alterations, they only weld
1 year ago
Welding is probably the best way to assemble a bike. It could be dangerous to glue a bike together because glue does not penetrate the metal like a weld would. It is far better to weld or braze metal or use bamboo than to try and glue a frame together, its simply not strong. Once you got a welder you wont be as dependent on buying expensive fasteners and hardware, you can make your own
10 years ago
one simple word, duck tape
Reply 2 years ago
That's 2 words
Answer 4 years ago
two words mf
7 years ago
Hi. How would I attach 2 pieces of metal together without using anything but the pieces themselves and be able to take the pieces apart as well? Can I make finer/box joints or jigs or some sort of joinery method? Any suggestions please. Thanks so much
10 years ago
get 2 screws and matching nuts , drill 2 holes and pu the nuts on then 4 extra support maybe duct tape orwell idk thats my answer :)
11 years ago
By the time you buy enough epoxy, rivets, and bolts, you could've already bought a cheap stick welder and some rods.
11 years ago
Brazing or soldering... It's like welding but much cheaper. Or just buy a welder... once you start... you will never stop.
12 years ago
tube and sleeve, if the part you are trying to join is hollow you could put a tube or bar stock into it and secure it with a drilled hole and bolt, or even jb weld. the tube or bar stock would be the structural component.
12 years ago
Bolts or rivets. Get an engineering manual (Machinery's Guide, for example) in order to do the calculations you will need to be safe.
12 years ago
Try some QUIKSTEEL Epoxy. It's like a putty, you cut off what you need, and you kneed it with your hands. it doesn't take long for it to set, but holds just as good as a weld does. You can even use it underwater. It's pretty good stuff. You can most likely find it at a hardware store, or possibly even wal-mart.
12 years ago
. A lot of epoxies will be too brittle for use on a bike. Most glues will not be strong enough (although I have zero experience with Gorilla Glue). . Binary Boy's bolts (or screws) and clamps should work well for proof-of-concept but probably won't hold up to hard use. . klee27x's brazing idea should work best but if you don't have access to a welder, you probably can't get your hands on a good torch.
12 years ago
bolts and clamps
12 years ago
try the JB weld. works for me ussually.
12 years ago
Google "brazing, silver soldering, silver brazing."
