22107Views6Replies
Author Options:
How do I attach wheels to a metal filing cabinet? Answered
I have a 5 drawer metal Hon lateral filing cabinet that I want to put wheels on so I can move it around. How do I do it?
steveastrouk
steveastrouk
Best Answer 11 years ago
I've seen it done as KMH suggests, but sometimes the steel of the cabinets is too thin to support the load, and the base collapses - locking the lower cabinet ! Put a thick piece of ply between the wheels and the cabinet.
StarPrincess
StarPrincess
Answer 11 years ago
So do I cut the plywood to cover the entire bottom or just 4 small squares to cover the caster bases? What size/ thickness of plywood? What size wheels? You guys are great!
steveastrouk
steveastrouk
Answer 11 years ago
MUST be the full base- its the strength of the corners that lets the original idea. 1/2" (12mm) ply works OK. Wheel size is up to to you, and the load rating of the wheels - larger wheels are likely to carry more weight. Ork's idea is good too.
orksecurity
orksecurity
Answer 11 years ago
I'd suggest essentially building a furniture cart and then putting the file cabinet on it. So: Either plywood, or 2x4's outlining the rectangle, or both (for rigidity); mount casters to bottom and put cabinet on top.
kelseymh
kelseymh
Answer 11 years ago
Better answer :-)
kelseymh
kelseymh
11 years ago
Empty the cabinet. Turn it upside down. Go to a hardware store. Buy casters with flat bases (small ones). Buy sheet metal screws. Drill pilot holes in the bottom for the screws. Screw the caster bases to the cabinet. Turn it upright. Put the files back in.
