2632Views8Replies
Author Options:
How do I clean my Aluminum Oxide bit for my Dremel? It has a coating of metal on the side.? Answered
I was probably using my dremel wrong, but my 932 bit has a coating of metal on it after I used it to enlarge a hole. (I ground using the side of the bit). How do I remove this coating of metal?
cerberustugowar
cerberustugowar
7 years ago
I may not be reading in to this enough, but it sounds like you used a soft metal on a bit that is meant for a harder material. You may be able to re-dress your bit by using an aluminium oxide dressing tool (like the square block, or maybe with a wheel dressing tool like the red one in the picture. http://www.micro-machine-shop.com/grinding_wheel_dressers.jpg . Or possible this is all overkill and it's just better to buy a new bit and if you need to grind a soft material, buy the appropriate bit.
alfonzo1955
alfonzo1955
Answer 7 years ago
What bit should I be using for a material like softer metals?
cerberustugowar
cerberustugowar
Answer 7 years ago
I would think your best bet for enlarging a hole (besides re-drilling it) would be a carbide burr. We use them at work (although it's in a 1/4" die grinder) and regularly use them on aluminium and steel. Another ideas may be to try those small sanding drums they have. Hope this helps in leading you to a solution.
rickharris
rickharris
7 years ago
For the cost of these tools - Buy a new one.
They are hardly worth the effort to reclaim them.
Although using a power tool seems like the easy choice often softer materials are better handled with hand tools such as files which can easily be cleaned.
steveastrouk
steveastrouk
7 years ago
I deleted my comment about etching, I assumed you'd used a toothed cutter too fast.
Grinding is only suitable for hard materials - or the wheel clogs...
On soft materials, you need a cutter with real teeth, usually called a "burr"
This range is suitable
http://www.dremel.com/en-us/Accessories/Pages/SubCategories.aspx?catid=2070&catname=High+Speed+Cutters
KEEP THE SPEED DOWN, and ideally lubricate the process slightly, using mineral spirit and a bit of lubricating oil.
Burf
Burf
7 years ago
Use the dressing stone that comes with most Dremel kits. Its a black, square carborundum stone about 1/2" square and an inch or so long.
Chuck the grindstone in your tool, turn it on and hold the dressing stone against the grindstone. It abrades away a little of the grindstone until the metal clogging the stone is removed.
In the future, use one of the steel cutting bits for shaping soft metal.
alfonzo1955
alfonzo1955
Answer 7 years ago
American Nickel, so 25% nickel, 75% copper
