5372Views3Replies
Author Options:
How do I connect a laser diode to a power source? Answered
I have a sony laser diode that will not work. I have tried to just solder the leads and connect it to a battery,but that is not working! HELP!
rostislav8
8 years ago
u might be using a ir laserf cause those you cant see the beam
Jordo
10 years ago
usually they take about 3v, make shure you have the polarity correct, the one i had had three leads.
If you already put too much voltage through it, it may be dead, this is how i killed my first diode,
make shure you also have a lens on it, to focus the beam.
If you look to to the right of this webpage there is an instructable for the NES ZAPPER!!! read that, it as a burning diode in it and might be able to help you furthur.
https://www.instructables.com/id/NES-ZAPPER!!!/
frollard
10 years ago
What type of laser diode is it? Does it have a part number? Check the spec sheet (google the part number) to find the pinout, and the voltage/amperage required. BE VERY VERY CAREFUL WITH THESE! if it's out of a dvd player, the beam will be almost if not totally invisible, but can cause instant irreversible damage from the amount of infrared (IR) radiation!!!
